Old 11-04-2012, 02:34 PM   #1
Need help with HW Drain
I can't seem to loosen the anode rod to drain the HW Tank. I just have basic tools and less than basic knowledge! WD-40? Special tool? Any advice would be welcome!
Jean LL is offline   Reply With Quote
Old 11-04-2012, 02:43 PM   #2
Oakman's Avatar
It takes a lot of pressure to get the anode rod out. I use a socket wrench set with the breaker bar.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 11-04-2012, 02:51 PM   #3
took mine out w/a 37mm socket, small extension and ratchet. was 1/2" drive. no problem.
bgarbo is offline   Reply With Quote
Old 11-04-2012, 02:57 PM   #4
took mine out w/a 37mm socket, small extension, and 1/2' drive ratchet. no problems.
Old 11-04-2012, 03:28 PM   #5
puff's Avatar
The bigger the socket and the wrench the more torque you will be able to apply. If it has not been removed in some time you might want to take a wire brush to the threads on the outside of the rod as close to the tank as possible clean them and spray them with some kind of good penetrating fluid. WD 40 is ok...but there are better choices.
Hope that helps.
Glen & Robyn (A.K.A. Puff & Crickit) Full Timers..
2006 F350 6.0 with 3.73 gears, 4X4, Extra-Cab Long Box, Oil/Tranny/P.S. Coolers. Coolant filter. SCT Livewire.
2011 Cedar Creek 36RE, Auto levelers + too much to list..!
puff is offline   Reply With Quote
Old 11-04-2012, 05:31 PM   #6
Oklahoma Proud
MillerTime's Avatar
Mine takes a 27mm or 1-1/16" and I used a twelve point socket.
I used a 3/4" set in the pic just cause I had it with the extension handy from changing my boat prop. The smaller rachet in pic is 1/2" drive and would have worked on mine just fine if i had put a extention on it.
(beer can was for size reference)
Old 11-04-2012, 06:04 PM   #7
VinceU's Avatar
Attachment 21389
Now that's descriptive!
Old 11-04-2012, 06:17 PM   #8
TURBS's Avatar
Attachment 21389
hmmmm "miller time" drinks "bud light ?"
Old 11-04-2012, 06:53 PM   #9
Oklahoma Proud
MillerTime's Avatar
Sorry for the distraction but I've never even tasted any of my namesake. Last name is Miller!!!
Old 11-04-2012, 08:07 PM   #10
hkreck's Avatar
On my Anode rod I had to tap the shocket with a hammer while appling pressure to get it to finally brake loss.
Henry & Tena
2013 Solera 24S
The Great Escape
hkreck is offline   Reply With Quote
