Old 09-13-2016, 11:08 AM   #11
contourcrazy's Avatar
Send a message via Yahoo to contourcrazy
Does anything else propane work on the coach?
2016 Wildwood 261 BHXL
2012 Ford F150 XL 5.0 L
contourcrazy is offline   Reply With Quote
Old 09-13-2016, 11:31 AM   #12
Head Rambler
Let me see if I have this right?
You're having problems with both gas and electric sides of the heater?
You've replaced the control module and it worked intermittently?
It's only worked on electric once for a little while?
Both Hi-limits are not tripped?
The gas and electric sides on that heater are completely separate except for being in the same compartment. Even the thermostats and hi-limits are separate for each side.
I think you need to start it and let it run till it stops, and then start checking for voltage along the circuit until you find where it stops.
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
Old 09-13-2016, 12:25 PM   #13
The stove works good but the furnace does not. But I think that may be another issue.
dagoose is offline   Reply With Quote
Old 09-13-2016, 12:31 PM   #14
It was working intermittingly even before I replaced module. And the electric worked at first and then stopped (the heater was full of water from the get-go). High limits are not tripped. But those high limits are right together in the same piece, aren't they? That may be a good place to start looking.
Old 09-13-2016, 12:39 PM   #15
It is possible tha you have an intermittant power problem to the igniter module. Check all connections.
Harkerr is offline   Reply With Quote
Old 09-13-2016, 12:52 PM   #16
I totally agree on check all connections. It seems like a loose or corroded connector.
SweetOleBill is offline   Reply With Quote
Old 09-13-2016, 01:43 PM   #17
Sounds like good advice. I'll be doing that this weekend.
Old 09-13-2016, 01:47 PM   #18
AKA: 'tiredTeacher
awellis3's Avatar
Originally Posted by dagoose View Post
Could there be a connection between the gas and electric BOTH not working? Are they tied together anywhere?
Ten years as an auto mechanic taught me that an electrical problem such as yours is often caused by the grounding circuit. It is common to both sides of the system and if loose or corroded can cause the problems you are having.
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
awellis3 is offline   Reply With Quote
Old 09-13-2016, 01:47 PM   #19
satdog01's Avatar
I am confused on the switch light that comes on when trying to use propane. When using propane, the DSl light should come on and go out after a few seconds and stay off until the switch is turned off. I had a bad control board and the DSL light never went out when the propane switch was turned on. The other light is for the electric only. If you are not getting warm water after 20 minutes or so there is an electric issue. Also not mentioned here, check the outside electrical switch on the the tank, it must be on as well. Look at it close, it is backwards IMHO in that it should be off when it is on.
Marriot2 on Wheels 2017 Flagstaff Classic 832 OKBS
2013 GMC Denali 6.6L 2500 HD DMAX w\Alison Trans
Pepper Pomeranian rescue 121 days as camping buddy
Days camped in FR, 2011 = 20, 2012 = 57, 2013 = 59
... 2014 = 39, 2015 = 52, 2016 = 77, 2017 = 11
Retired :
satdog01 is online now   Reply With Quote
Old 09-13-2016, 02:09 PM   #20
Had the same problem, Found it was the switch in the master panel where you turn it on and off. .. Replaced the switch and have had no problems since.
2014 SUNSEEKER 3010DS
TOADS, 2012 FOCUS OR 1998 JEEP WRANGLER,
Kevin & Judy is offline   Reply With Quote
