Old 06-29-2016, 10:12 PM   #11
Left Coast
If water can't get in, the check valve is installed backward...
Bob/Linda, 99 Dodge 2500 Cummins,2010 8280 Rockwood Ultra-lite 5er, PullRite Superglide----- I'm retired......but work part time as a pain in the ass!........... USMC.
Old 06-29-2016, 10:16 PM   #12
Since I am looking at putting some kind of water inlet valve/plug into the top of my potable water tank, can I just install a gravity fill connection like the one in post #5 of this thread and seal it good with silicone sealer or synthetic plumber's putty without the oil in it? Thanks.....
2015 Forest River Wildwood X-Lite 241QBXL
2007 Red Ford F-150 XL Pickup truck
rodneyranger is offline   Reply With Quote
Old 06-29-2016, 10:21 PM   #13
Originally Posted by bikendan View Post
She has the 183.
I was googling them trying to see if she has a gravity fill, but didn't find any pics close enough. There might be one just to the right of the hot water heater, but I'm not sure.
1988 Coleman Sequoia - popup (1987-2009)
2012 Roo19 - hybid (2012-2015)
2011 Traverse LT, 3.6L, FWD
2009 Silverado Ext Cab, 5.3L, 4x4, 3.73
Old 06-29-2016, 10:42 PM   #14
Left Coast
If it's got a fresh water tank from factory, it's got a fill already there...
Old 06-29-2016, 10:46 PM   #15
Summer2Go
Summer2Go's Avatar
It's labeled "anti freeze inlet". Is that where I put the water to fill it last year?
Summer2Go is offline   Reply With Quote
Old 06-29-2016, 10:53 PM   #16
You haven't responded concerning whether you have a gravity fill connection or not. It will look like the one in post 5, but is probably black. When you remove the cover, there will be no thread for a hose fitting. There will be a small meshed hole on the side for the vent. This is what you are expected to use to fill. You will need to fill it slowly. Stick the end of your hose into the hole and fill slowly.
Old 06-29-2016, 10:58 PM   #17
Summer2Go
Summer2Go's Avatar
I'll take pictures if I don't figure it out first in the AM.
Old 06-29-2016, 11:01 PM   #18
Summer2Go
Summer2Go's Avatar
No gravity fill. I need to write things down when I learn them!
Old 06-29-2016, 11:19 PM   #19
If you have no gravity fill, then you should have a valve from the city water connection that bypasses the water pump and goes to the FW tank.
But I'm very surprised if you don't have a gravity fill. My 2016 Mini Lite has one. Since folks are more likely to boondock in your TT than mine, I'd expect a gravity fill.
Old 06-30-2016, 01:47 AM   #20
Moderators' Assistant
bikendan's Avatar
It has to have a gravity fill.
All Roo/Shamrocks have one.
Dan-Retired Firefighter/EMT
'07 Roo 23SS pushing an '07 Chevy Avalanche
Equalizer WDH and Prodigy BC
tank
