Old 06-30-2016, 07:48 AM   #21
Summer2Go
Summer2Go's Avatar
I found it. I forgot everything from last year! I remembered switching the pump, and having trouble finding the switch on the wall side behind the pump! Thanks you guys, I was rushing.
Summer2Go is offline   Reply With Quote
Old 06-30-2016, 07:59 AM   #22
Summer2Go
Summer2Go's Avatar
The pictures, should anyone benefit from my mistake! The gravity feed, the city water and antifreeze connections, and my blasted water pump in the front corner of the storage (that I can barely fit my head into).Click image for larger version
Name:	ImageUploadedByForest River Forums1467287887.797894.jpg
ID:	112654Click image for larger version
Name:	ImageUploadedByForest River Forums1467287920.403172.jpg
ID:	112655Click image for larger version
Name:	ImageUploadedByForest River Forums1467287962.002810.jpg
Old 06-30-2016, 10:23 AM   #23
Great. Now if you still have trouble getting water into the gravity feed, you might want to try one of these:
Camco Water Tank Filler with Shutoff Valve - Walmart.com
1988 Coleman Sequoia - popup (1987-2009)
2012 Roo19 - hybid (2012-2015)
2011 Traverse LT, 3.6L, FWD
2009 Silverado Ext Cab, 5.3L, 4x4, 3.73
Old 07-13-2016, 08:16 PM   #24
Summer2Go
Summer2Go's Avatar
My water pump was in the wrong position, it was still in the anti freeze position, I think. The city water worked just fine, but it would not pump the water when on the fresh water tank. The water lines do not make sense to me. I'll just make note of which way it should go!
Old 07-13-2016, 10:24 PM   #25
Summer2Go
Summer2Go's Avatar
This switch should be in line with the white pipe, not the blue.
Name:	ImageUploadedByForest River Forums1468462982.546059.jpg
tank
