Old 07-21-2015, 07:49 PM   #1
Mr. Dan's Avatar
Need help with sewer valve cable
By what means should these sewer valve cable sleeves be attached to the aluminum stems which come through the wall? It's pretty hard to close my black tank valve if the sleeve is not stabilized.
Sent (I think)
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 86; booked = 0
Old 07-24-2015, 07:37 AM   #2
Mr. Dan's Avatar
Oh, well.
I'll try my own homemade fix. If that doesn't work, I'll operate the black valves with both hands until I get to Goshen.
Thanks.
Sent (I think)
Old 07-24-2015, 07:49 AM   #3
Looks like the (Retaining Nuts) came OFF, hope they are on the Cable down stream if not maybe they didn't put them on the Cable? Youroo!!
Old 07-24-2015, 10:04 AM   #4
Mr. Dan's Avatar
Nope, no retaining nuts on any of the three cables. The only other parts not seen (behind the wall) are a plastic grommet to fill the hole in the wall and a nut to tighten on the threaded aluminum to secure the cable handle end to the wall.
Sent (I think)
