Old 11-03-2013, 03:37 PM   #1
Rev Roy's Avatar
Need New Check Valve For Suburban Water Heater
I need to replace the check valve in the hot water connection on my Suburban hot water heater. Any suggestions on where I might get one online? I've been Googling it with no luck. Here's what the heater looks like.
2007 Rockwood Signature Ultra Lite
Rev Roy is offline   Reply With Quote
Old 11-03-2013, 05:02 PM   #2
Just google "suburban water heater parts" and you'll get lots of hits.
Old 11-03-2013, 05:11 PM   #3
Rev Roy's Avatar
I get that far no problem...but I'm still not finding a "check valve." Is it called something else, too?
Old 11-03-2013, 05:39 PM   #4
DDC
DDC's Avatar
Do you mean the relief valve?
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is offline   Reply With Quote
Old 11-03-2013, 05:43 PM   #5
Check valves usually go bad, or do not work because of something in the valve. Pull out the valve and check for debris in and around the valve. this might be a post suburban add on and not available from suburban. might have to try lowes home depot or grainger if valve is bad.
Rockwood 8282 WS
2012 F-250 6.2
farfetched is offline   Reply With Quote
Old 11-03-2013, 05:48 PM   #6
Rev Roy's Avatar
I'm a newbie to all this, but everyone on the FR forums and elsewhere have called it a "check valve." I lost pressure in my hot water lines and it ended up being this valve that had broken up and blocked the line. Apparently it is there to keep the water moving one way so the cold water doesn't mix with the hot...
