Old 04-30-2013, 06:18 AM   #1
MI Camperz
bodzcampers's Avatar
Need that Black Tank Recipe
Heading to seasonal and will be de-winterizing and hooking up sewer, etc.
I read about a recommended prep for the black tank using dish washer soap, laundry soap, and water....should have written it down but didn't. Can anyone please share that "recipe"? It's supposed to keep things cleaner.
Thank you in advance for your replies. Leaving in 2-3 hours.
MI Camperz
bodzcampers is offline   Reply With Quote
Old 04-30-2013, 06:27 AM   #2
The Geo Method????
  • Calgon Water Softener -> This stuff helps to break down water surface tension, clean scum and prevent hard mineral deposits. I’ve used Borax on occasion when I can’t find Calgon and find it works just as well.
  • Dawn Dishwasher Detergent -> The “original formula” blue detergent is excellent at cutting grime. Laundry detergent works too.
After you dump pour 1 cup of Calgon and 1 cup detergent into the tanks. Leave them in until your next dump. Before driving some RVers will also throw a bag of ice-cubes down the tank to “scour” their walls (we’ve never done this, but others swear by it)
I add a gallon of warm water if using the calgon powder. If using the calgon liquid I use a couple of capfuls and mix it all in the toilet and then flush.
Pipeman is offline   Reply With Quote
Old 04-30-2013, 06:38 AM   #3
Oakman's Avatar
De-winterizing, YEA! Winter is over.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 04-30-2013, 06:39 AM   #4
MI Camperz
So, it's not Calgan dish washer soap?
If I can't find Calgon water softener, how much borax do I use?
MI Camperz
Old 04-30-2013, 06:43 AM   #5
Oakman's Avatar
Walmart usually has Calgon water softener but they don't carry a big stock of it. Ask a clerk if you don't see it on the shelf. Our Walmart has it in the laundry section.
Bob and Joyce
ATU Local 788
Old 04-30-2013, 06:44 AM   #6
TURBS's Avatar
Here's also a helpful hint.
Some campers maybe yours maybe not, the drain pipe is a few feet long before it gets to outlet valve.
What this means is if you dump tank empty then add "Recipe" and a gallon of water it all sits in he outlet pipe and never in tank.
You want to consider adding several gallons of water then adding recipe with another gallon of water.
I mix mine in an ice cream bucket with hot water then dump into tank that I've added 2 gallons to already.
Old 04-30-2013, 06:46 AM   #7
MI Camperz
It makes sense to add the water at the start to mix things up.
MI Camperz
Old 04-30-2013, 06:48 AM   #8
MI Camperz
So, it's one cup each of Calgon Water Softener and Laundry Detergent with several gallons of water to start. Is that correct? If I can't find water softener, use borax? Right?
MI Camperz
Old 04-30-2013, 06:50 AM   #9
TURBS's Avatar
Any liquid water softener will work.
Old 04-30-2013, 06:51 AM   #10
MI Camperz
Thanks...prolly have better luck finding it near CGS than near home...we have city water....LOL
Do I still use the toilet tabs at the same time?
MI Camperz
Old 04-30-2013, 06:53 AM   #11
Dave Lyon's Avatar
Google "Geo Method" that will priovide you with all the information you need.
Dave, Southern,ON
2017 GMC SLT HD All Terrain Crew Cab (6' 6" Box) 2012 Roo 23SS
E2 Trunnion WDH (1,000 lb / 10,000 lb)
Dave Lyon is offline   Reply With Quote
Old 04-30-2013, 06:54 AM   #12
TURBS's Avatar
No need but can if u want.
Old 04-30-2013, 06:56 AM   #13
MI Camperz
Well, if it won't hurt and it's not too much, I will. Some threads include bleach....what's your take on that?
MI Camperz
Old 04-30-2013, 07:00 AM   #14
TURBS's Avatar
Not sure I've heard bleach before.
I strictly use geo-method.
Old 04-30-2013, 07:01 AM   #15
MI Camperz
Okay, Thank you very much. Check out the cool scooters this guy has in Seasonal Thread. I'm jealous.
MI Camperz
Old 04-30-2013, 07:04 AM   #16
I found out that about 2 cups of Super Clean and 2 gal of water works great also. Breaks up the junk and makes the tank slick. Tried it in FL this last winter and I think when the tank empties, it starts flowing clear water a little faster when using the tank flusher. Just my opinion.
Old 04-30-2013, 07:05 AM   #17
MI Camperz
What is Super Klean? Where do I find it? Thank you.
MI Camperz
Old 04-30-2013, 07:06 AM   #18
Oakman's Avatar
I have read that chlorine is bad for gaskets and seals so I don't use it. I use the softener, detergent, and a black tank chemical. I put the chemical in to help break down solids. The last thing I want is a problem with the black tank. I'm sure your dealer's service department feels the same way.
Bob and Joyce
ATU Local 788
Old 04-30-2013, 07:08 AM   #19
MI Camperz
Thanks. I agree. I bet the service people do too!
MI Camperz
Old 04-30-2013, 07:15 AM   #20
I spelled it wrong, it is Super Clean and I get it at Walmart in 1 gal jugs (automotive dept) purple jug. Use it full strength to clean tires also.
