Old 12-26-2018, 10:32 PM   #41
Canadian Member
Wayne O, did you figure out what you can use to use the hoses you have? It sounds like you can use 3 - 15’ hoses. Use a single 15’ hose for the short side. For the 27’ distance, you can connect two 15’ hoses with the swivel coupler fitting and then use the tee at the dump port for both sides.
Old 12-26-2018, 10:44 PM   #42
I got the swivel fitting that I'll be replacing the 90 degree fitting this week to be able to connect the 2 hoses together. Not worried about having both ports hooked up at the same time since the trailer isn't used all the time. I just needed a way to be able to disconnect from the front to dump the back port.
I may end up getting another 15' hose and T at sometime to be able to have both dump ports hooked up at the same time. Click image for larger version
Wayne O is offline   Reply With Quote
