Old 11-12-2014, 04:07 PM   #1
Need winterizing advice
I will be leaving my RV at the campground tomorrow morning. Forecast for the next three nights is right at 30 degrees, but just for a few hours...rebounding into the 40s during the days.
I am disconnecting the water hose, draining the low points. I don't have a compressor, so won't blow out pipes.
Will this suffice, or do I need to blow out the lines?
Larry Tiner is offline   Reply With Quote
Old 11-12-2014, 05:27 PM   #2
arpipeliner's Avatar
I think u will be fine.
arpipeliner is offline   Reply With Quote
Old 11-12-2014, 05:54 PM   #3
mark0224's Avatar
If you can empty the water heater do it because it is exposed to the outside. A small dc air compressor is a good cheap thing to carry or a jump pack with air compressor in case of emergencies.
Think about things before you do them make life easier not harder.
mark0224 is offline   Reply With Quote
Old 11-12-2014, 06:01 PM   #4
WFD
You will be fine...I don't think you need to drain the water heater, granted one side of it is exposed but it is insulated and sits inside the trailer. We have been out with ours in temps getting down to 27-28 and had no issues. Wise to disconnect your freshwater supply...
Thing to remember is that when you are risk of frost for a short time like that, then temp normally only hits that frost point shortly before sunrise and only stays there a cpl hrs.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 11-13-2014, 08:36 AM   #5
I have the same issue but we will have freeze warning for 12 to 14 hours on 2 to 3 differant nights. I will disconnect the fresh water and drain low point. We get power from a generator so connecting a small heater is not an option. I will disconnect the fresh water line. Not sure if this is a good ideal so i'll put it out there. i was thinking about pouring a gallon or 2 of rv anti freeze in the fresh water tank (turn on by pasess) run the pump till the anti freeze comes out the lines. When i return re-connect the fresh water supply and run it to purge the lines of the anti freeze. We dont drink or cook with the water we only use bottled water for that.
When i leave the next weeked repeatsteps. Flush the fresh tank with bleach before i use it ater i pull it off the proprty in about 3 weeks.
At home my tt is connect to power and i have a small heater running in the tt to keep it above freezing.
2013 Ram 1500 (5.7)
2014 Rockwood Mini Lite 2104s
http://i307.photobucket.com/albums/n...ps412bc14c.jpg
Prothos is offline   Reply With Quote
Old 11-13-2014, 08:58 AM   #6
Witch Doctor's Avatar
Prothos, I would not put anti freeze in my fresh water tank. Depending on the drain height to the tank you may never get it all out. Just drain your FW tank drain your low points, and hot water heater and let it go, you should still be okay. Put some pink in gray and black and pee traps. If it gets above 32 each day you will not have a problem that I can see.
Coachmen M/H
Concord
2018 / 300 DSC
winter, winterize
