Old 10-25-2013, 01:41 PM   #1
RKR
RKR's Avatar
New 5ver
We just purchased a 2013 325MKS. We tool it out on our first trip. I'm currently sitting in the trailer while writing this.
The question I have is this. Does the sink drain pipe that empties out behind the axles always need to be tied into a drain ? I was curious that if I leave the cap on does it fill the lube and then flow into my gray tank ? It only has one gray tank. When I dump the gray tank from the connection in front of the axles no fluids come out of the rear.
I going to put a 2" ball valve in the line to make sure it seals off. We spent the first night with it leaking onto the ground. The cap was a little loose.
Any ideas from somebody with a similar set up would be appreciated.
Thank you
RKR is offline   Reply With Quote
Old 10-25-2013, 01:45 PM   #2
RKR
RKR's Avatar
Sorry for the spelling. Accidentally sent it before proof reading.
Old 10-25-2013, 02:54 PM   #3
Fulltime family RVer
I'll be honest- I'm not sure what pipe/drain you're talking about. Are you able to take a picture and post it?
Old 10-25-2013, 03:53 PM   #4
5erDriver's Avatar
I have a feeling you are looking at your low point drain. Should be capped except for just that, draining system.
2013 Sandpiper 365SAQ
2008 Ford F350 Super Duty
6.4L Powerstroke Long Bed CC
5erDriver is offline   Reply With Quote
Old 10-25-2013, 04:06 PM   #5
I'm pretty sure that I agree.
Old 10-25-2013, 04:09 PM   #6
Oakman's Avatar
It sounds more like the drain for the fresh water holding tank to me. What brand of trailer do you own?
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 10-25-2013, 04:23 PM   #7
Any ideas why it might weep water for that first night?
"We spent the first night with it leaking onto the ground. The cap was a little loose. "
And, looks like a Coachmen - Chaparral - 325MKS based on model #.
Old 10-25-2013, 04:24 PM   #8
RKR
RKR's Avatar
Pic
When I turn the sink on the water runs out the line in the pic. It's a 2" line with a 4" cap. When I open the gray tank to dump it nothing comes out of that line just the line in front of the axles.That's why I think it's just a sink drain line , if that makes any sense. Thanks for the advice. Here's the pic.
Old 10-25-2013, 04:27 PM   #9
Unfortunately, you pic didn't make it.
Was there just one? Or were there two? And what color was it?
Old 10-25-2013, 04:45 PM   #10
RKR
RKR's Avatar
There are 2 lines.One in front of the axles that I have already used dump grey and black. The rear line is the one I had questions about. The sink water runs out of it. Nothing comes out of the that rear line when I pull the grey dump valve open.
