Just purchase last evening, fill water tank 2/3, went CG hooked up, no water on. Try using 12V system can't get a drop of water need help!
The system work @ dealership, we did walk thru saleman put water filter in and we left.
We are at CG for week need help asap.
Tincup
Check water pump, sometimes they ave a bypass for anti freeze if that is set to on then you get nothing.
Just purchased NEW last evening. Did walk thru with salesman, water worked, salesman put inline filter in bottle. We stop filled fresh water tank 2/3 full.
Got to Rv Park hook up trailer no city water available then try 12V systm can't get a drop. Pump runs n, water. Need help
Tincup
It sounds like a air lock - air in the line - open several faucets to see if you can get the air out of the line.
You did not say if the trailer was on city water at the dealership.
Obviously you should check the drain valve on the tank and that there is still water in the tank. I presume you have done that.
Other possibilities might be:
If the trailer has an antifreeze kit installed, the three way valve might be turned in the wrong direction or the cap may not be on the fitting.
Reversed polarity on pump causing pump to run backwards.
Loose pickup hose at tank so that pump is sucking air, not water.
Defective pump.
I also am presuming that, since you had water at the dealer, that your piping and faucet aerators are not clogged.
Hope you find the problem soon.
Thanks, it was working @ dealer, the inline filter container has only a couple inch in it. I think it may be a air problem
