Old 08-25-2014, 09:26 AM   #11
Zoeneens's Avatar
Thanks!
Zoeneens is offline   Reply With Quote
Old 08-25-2014, 09:28 AM   #12
Zoeneens's Avatar
Doesn't show on my ipad...the library. Anywhere else I can find it?
Old 08-25-2014, 09:30 AM   #13
wmtire's Avatar
Hmmm, this is something I need to run by the site tech team.
Try this direct link:
Forest River Forums - Downloads - Thermostat - Dometic Comfort Control Center 2
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 08-25-2014, 09:36 AM   #14
I have a CCK. The switch is located in the bedroom closet *with the sliding mirror doors) on the right hand side. It looks like a residential light switch. When on, is should be an orange color.
One more thing, make sure at your water heater you turn both white by-pass valves so your heater will fill up.
It will take about 2-3hrs for the 20gal of water to get hot.
2014 Cedar Creek Cottage 40CCK
stever40 is offline   Reply With Quote
Old 08-25-2014, 09:41 AM   #15
Zoeneens's Avatar
The water heater tank was filled before delivery. This unit was not "winterized?" Where are the bypass valves. Do you have a picture?
Old 08-25-2014, 09:44 AM   #16
wmtire's Avatar
Your bypass valves are shown in your post#3 here. I had glanced at them previously and they were set correct.
Old 08-25-2014, 09:44 AM   #17
TURBS's Avatar
The by pass valves are in the pictures you provided.
They are in the "summer" position already.
TURBS
"SABRE OWNERS UNITED"
Old 08-25-2014, 09:44 AM   #18
Please disregard my previous post about the heater switch. I didn't read that you found it.
For the Dometic dual controller. Set the clock first, then you can program it to what you want. I will say good luck getting this thing to balance if you have it on "Auto". I have given up with that feature and just programmed the two AC on "Cool" and when it gets cold enough I turn it over to "Heat".
I found that the "Auto" selection makes the two thermostats compete. I could have AC on in the bedroom and heat on in the main area of vise versa. It is a real PITA.
Good luck and hope you enjoy your CCK as much as we do.
Old 08-25-2014, 09:46 AM   #19
TURBS's Avatar
Hi Everyone! I moved into my 2015 Cottage CCK and no hot water. Using well water so it is COLD The heater is electric, the switch light is on in the inside control panel. Am I missing something? TIA
You either didn't have a very good pdi or your dealer didn't give you one and I'd be very leary of future service work.....
TURBS
Old 08-25-2014, 09:46 AM   #20
Zoeneens's Avatar
Yes...found the switch for water heater! My thermostat is on auto.....glad to hear you are enjoying your CCK. I have had a bit of a rough start learning how all this works!
hot water, water
