Old 08-25-2014, 10:47 AM   #31
jkaspar20's Avatar
The key on duel acs is the zone. Zone 1 is main cabin. Adj temp and fan speed usually auto. Then jump tp zone 2 and do the same. You can also turn off each unit. If you only want to cool one area. FYI TMI if there is large temp chng cool to warm heater/ac will kick in to balance air temp.
Sent from my SCH-I545 using Forest River Forums mobile app
jkaspar20 is offline   Reply With Quote
Old 08-25-2014, 12:54 PM   #32
This is where I struggle. It makes absolutely no sense to me why the heater and the A/C would be on at the same time to balance. Regardless of temp change.
I have tried to adjust zone 1 and 2 to prevent the heater to kick in. It's really interesting that the main room thermostat is telling the controller it needs A/C and the bedroom thermostat is telling the controller it needs heat (or vise versa). I just laughed(out of frustration) when I saw both running at the same time.
2014 Cedar Creek Cottage 40CCK
stever40 is offline   Reply With Quote
hot water, water
