Old 08-24-2014, 01:28 PM   #1
Zoeneens's Avatar
New Cottage CCK no hot water!
Hi Everyone! I moved into my 2015 Cottage CCK and no hot water. Using well water so it is COLD The heater is electric, the switch light is on in the inside control panel. Am I missing something? TIA
Zoeneens is offline   Reply With Quote
Old 08-24-2014, 01:43 PM   #2
Ford Idaho's Avatar
Welcome to the forums and congratulations on the new lifestyle.
Is this one on?
Old 08-24-2014, 02:43 PM   #3
Zoeneens's Avatar
Name:	ImageUploadedByForest River Forums1408909359.529133.jpg
ID:	61365. This is what I have. Can't find a switch.....
Old 08-24-2014, 02:43 PM   #4
Zoeneens's Avatar
Name:	ImageUploadedByForest River Forums1408909414.751162.jpg
Old 08-25-2014, 07:43 AM   #5
Zoeneens's Avatar
Inside control panel says "switch in closet". Does that mean the closet the tank is in? I'm thinking it is behind the wood that is used to stabilize tank during transport seen on picture
Old 08-25-2014, 08:59 AM   #6
jkaspar20's Avatar
Check circuit breaker
jkaspar20 is offline   Reply With Quote
Old 08-25-2014, 09:06 AM   #7
jkaspar20's Avatar
After thought: Find papers and see if there is a switch. Take panel off where power wires come in and with VOM see if you get 120volts. Circuit breaker panel is in bedroom closet on . check heating element wire may have come off. If you have power. your element is most likely bad
Old 08-25-2014, 09:12 AM   #8
Zoeneens's Avatar
Just spoke with tech support. The switch is in the BEDROOM closet. If only the label had specified which closet!!
Old 08-25-2014, 09:13 AM   #9
Zoeneens's Avatar
Thanks for all your help. Now to figure out dometic 2 zone air. No manual. Ugh!
Old 08-25-2014, 09:25 AM   #10
wmtire's Avatar
If you will look near the top of any Forest River Forum page, you will see a "Library" tab (between "User CP" and "FAQ"). Click this and you will find a plethora of manuals on many different items.
Hope it helps.
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
hot water, water
