Old 10-20-2011, 07:55 PM   #1
Herk7769's Avatar
New Thread from Water Pump questions
Oh, like F100turbo said; NEVER put RV antifreeze in the fresh tank. UGH
You will never get the taste out of the water.
Just drain using the outside drain spigot.
HAM CALLSIGN - KC3FFW
Old 10-20-2011, 07:55 PM   #2
(Kim)
Labzy's Avatar
Thanks so much for your input, all of you!!
I seriously don't know what I would do if this forum wasn't here, you are all so helpful!!
I will check on the pump as soon as I get my battery recharged and I will report back here
Everyone please keep your fingers crossed for me that it still works.
2010 Dodge Ram 1500
2012 Rockwood 2306
Kim
DH (Alan), DD (Madison) and Zoey the lab,
Labzy is offline   Reply With Quote
Old 10-20-2011, 08:18 PM   #3
(Kim)
Labzy's Avatar
Btw.......when by-passing WH, what direction do the levers go, vertical to the hose or horizontal to it?
I just want to make sure that those guys did it since there was antifreeze around the WH area I am not sure if they by-passed it or not.
2010 Dodge Ram 1500
2012 Rockwood 2306
Kim
Old 10-20-2011, 08:23 PM   #4
Rugged Brown's Avatar
The water lines in and out of the water heater should have the levels turned at a 90 degree angle to the lines. The bypass level should line up with the water line. I'm sure Lou (HERK) should have an illustration that he can post for you.
Terry/Bernadette
Lily the Yorkie
2015 Dodge Ram Sport 1500
2015 Crossroads Zinger ZT28BH
Rugged Brown is offline   Reply With Quote
Old 10-20-2011, 08:34 PM   #5
(Kim)
Labzy's Avatar
I can only hope for a diagram,....hint.....hint.......
But you are saying that when the bypass is 'on', the levers are parallel with the water line, when bypass is 'off' they are at 90 degree (perpendicular) to line?
2010 Dodge Ram 1500
2012 Rockwood 2306
Kim
Old 10-20-2011, 08:44 PM   #6
There are 3 levers. The water supply (cold) and the hot water line. These should be at 90. The lever between these 2 lines should be parallel.
lou: help out with your illustration.
Terry/Bernadette
Lily the Yorkie
Old 10-20-2011, 09:18 PM   #7
Herk7769's Avatar
The photo shows the valves in the "operate" positions. They should be turned 90 degrees to be in bypass.
Old 10-21-2011, 08:04 AM   #8
(Kim)
Labzy's Avatar
Ahh, they say a picture is worth a thousand words, and it is so true.
It is much easier now to understand that the bypass line needs to be 'open' ( lever parallel with line) and the hot and cold intake lines be 'closed' (lever @ 90 degrees).
I really needed this diagram so when I check to see if they actually did bypass the WH, I will know exactly what to look for.
Thank you!!!!!
2010 Dodge Ram 1500
2012 Rockwood 2306
Kim
Old 10-21-2011, 11:49 AM   #9
Thank you!!!!!
Herk always comes through in a crunch.
Terry/Bernadette
Lily the Yorkie
Old 10-21-2011, 12:07 PM   #10
Herk7769's Avatar
Awe Shucks.
Also be aware there is a possibility of a two valve bypass kit using three-way "T" valves. These valves should only be able to turn 90 degrees, so they will both turned the same way to isolate the tank.
You can tell you have a two valve system ONLY IF you have 3 hoses going into each valve. It you have just two valves with only two hoses going in each one; then you do not have an isolation kit installed.
