Old 10-10-2014, 09:48 AM   #1
New To Winterization
36 foot Salem FLBK.... anyone know where the water pump is. going to the campsite to Winterize this weekend, and none of the manuals that came with the recently purchased camper, tells me this. any other advise on winterizing is also welcome.
chfan558 is offline   Reply With Quote
Old 10-10-2014, 10:11 AM   #2
ColoradoRick's Avatar
I'm not familiar with your camper but, normally, it's located underneath the mattress. (In it's own compartment or easily accessible from underneath in a storage place.)
And easy way to find it is to turn on your water pump and run a faucet...and let your ears guide you!
With my old camper, the BEST thing I ever did was install a winterization kit...made the job super easy.
Here's what a typical water pump looks like:
http://3.bp.blogspot.com/_lDvLM2IvPh...bFreshPump.jpg
Here's what the winterizing bypass kit does...you just put the valve on the line that comes from out outside water input...when you switch the valve, it pulls from the tube that you have inside the antifreeze jug to fill the lines/faucets with antifreeze.
http://www.richfieldtrailer.com/wp-c...2/10/36543.png
Rick & Karen
(Retired USAF, MSgt)
Monument, Colorado
6-year Travel Trailer RVers
2013 Forest River Rockwood Ultra-Lite 2904SS
2014 Toyota Tundra Maxcrew SR-5 TRD 4x4 (with Firestone airbags in the rear)
ColoradoRick is offline   Reply With Quote
Old 10-12-2014, 09:28 AM   #3
Maron
Send a message via Yahoo to Maron
I just finished winterizing my 2014 Rockwood 8329 TT. The water pump was behind a screwed shut door under the bathroom sink. Also under there was a bypass valve that allows you to pump RV antifreeze into the water system without filling the 30 gallon fresh water tank.
Maron is offline   Reply With Quote
Old 10-12-2014, 09:33 AM   #4
Maron
Also I found out from Forest River people that all Forest River RVs (at least newer ones) have built in bypass valves for the hot water heater. You don't want to leave antifreeze in your hot water heater.
On the 8329 access to the hot water heater is located in a cabinet under the main cabin sink.
Old 10-12-2014, 09:57 AM   #5
Canadian Member
itat's Avatar
Chfan558, put some water in your freshwater tank and turn on the pump. You'll discover where it is pretty quickly. It may be behind a screwed on panel that you have to remove to access the pump. If you don't have an antifreeze inlet on the outside of your Salem, the bypass kit is a must have addition.
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer WDH
2009 Ford F-150 XLT SuperCrew, 5.4L, 5'6" bed (2012 - 2016)
Old 10-12-2014, 10:20 AM   #6
Taranwanderer's Avatar
Why would this be an issue? In the past, I've drained my HWH, blow out all the lines, then pump a little AF into the HWH, then pull the anode rod (a little AF spills out,) then flip the bypass valves and pump AF to the rest of the trailer. Is there a specific reason you shouldn't have AF in the HWH, other than the cost of the AF? Again, I don't fill it, just leave a little siting in the bottom of the HWH to keep any residual water in there from freezing.
2015 XLR Hyperlite 30HFS5 (mods being performed regularly)
2009 Salem LA 292fkds (gone)
Nights- ('12)23 ('13)23 ('14)15 ('15)31 ('16)27 ('17) 20
2016 Ford Fusion Titanium (gulping gas again, camping support vehicle)
2014 Harley Davidson FLHX (XLR cargo)
2011 Ram 2500 CC 4X4 CTD, B&W Companion (toy hauler hauler)
Taranwanderer is offline   Reply With Quote
Old 10-12-2014, 10:23 AM   #7
Maron
The little water that is left in t,here has plenty of room to expand if it freezes plus cooked antifreeze is bad for the unit.
winter
