Old 04-17-2015, 12:03 PM   #11
And DON'T keep the valve to your blank tank open while at the campground thinking "stuff" will roll right through. Dried up tank in the summer full of "stuff" won't make for a pleasent experience
Nastyfoot is offline   Reply With Quote
Old 04-17-2015, 12:13 PM   #12
RVBikers's Avatar
Originally Posted by itat View Post
Before you buy something like the Flush King, watch this video.
http://youtu.be/dfTd0Slt_cU
X2!
definitely good info.
Jim & Evelyn
-2015 Ford F-350 XLT Dually
-2016 Prime Time Spartan 1242X
-2012 Harley Davidson Street Glide (his)
-2004 Harley Davidson Fatboy (hers)
RVBikers is offline   Reply With Quote
Old 04-17-2015, 12:30 PM   #13
Evereddie's Avatar
Originally Posted by gofastman1 View Post
Depending on what chemicals you choose, most will tell you to put 1 gal of water in your tank or mix it like a ratio, whatever.....so you will never know from one to the other, how much water you have in your black tank....I pre fill a milk jug before going to the dump station, then once im done dumping, I drop 2 tablets and 1 gallon of water, that way on the way home it helps wash the tank a little bit and I don't forget either. I never have a stinky camper because I forgot
I would use more than I gallon. The pipes on the way to the shut off valve take almost a gallon depending on your trailer.
Evereddie is offline   Reply With Quote
Old 04-17-2015, 12:41 PM   #14
ColoradoRick's Avatar
We've never had any issues with our black tank (like the dreaded clog) and follow a few rules:
- Thick rubber gloves that come almost up to my elbow whenever handling the sewer lines.
- Using an old hose to stick into the toilet to fill it or rinse it. (Never use your drinking water hose)
- Never messing with the black tank at dumping stations. Always quick in and out as people are waiting.
- Never dumping the black tank unless it's almost full and NEVER leaving the valve opened when parked at a full-hookup. If we need to bug out and it's not full, we'll start the night prior by doing long flushings to get it filled up.
-After dumping it, put about a gallon in there with some disinfectant or detergent. (Simple Green is cheap and smells great.)
- When dumping, always dump the black tank first than the gray to flush out the line.
I always keep a package of baby wipes in my truck to clean up after doing just about anything...setup/teardown/sewer management.
Rick & Karen
(Retired USAF, MSgt)
Monument, Colorado
6-year Travel Trailer RVers
2013 Forest River Rockwood Ultra-Lite 2904SS
2014 Toyota Tundra Maxcrew SR-5 TRD 4x4 (with Firestone airbags in the rear)
ColoradoRick is offline   Reply With Quote
Old 04-17-2015, 12:42 PM   #15
As some others have stated the Rhino hose is the way to go. I debated on if it was worth the higher price when we bought our 5er. Would not have anything else now. Ours was a kit with 2 10' hoses, the elbow and caps for the hoses. Have since bought the clear 45 elbow.
Steven & Tiffany
2015 Crusader 296BHS
2013 Chevy 2500HD LTZ CC Z71
Camp as often as we can
Steven379 is offline   Reply With Quote
Old 04-17-2015, 12:44 PM   #16
Strongly reccomend Thetford aqua-kem liquid. You can get 6 bottles (8oz) at Walmart very inexpensively. I pour a bottle in after each dump and flush a few times. This is the only stuff that cleans the sensors (which everyone says are a bad design) so the tank indicators actually show empty. I also agree with all who mentioned the clear elbow so you can check on the flow
Stlcaly is offline   Reply With Quote
Old 04-17-2015, 01:44 PM   #17
Always drain your black tank then your grey, that way the gray water flushes out the hose. Double check on the black tank flush, most of the new RV' have them. That is something that will help flush out the black tank. The flush king is great for breaking a plug at the valve. If the pipe doesn't go directing into the tank (travel trailer), but up (motor home and/or 5th wheel) you'll need the flush king with the extra valve on it.
Good luck
tomrob1161 is offline   Reply With Quote
Old 04-17-2015, 01:56 PM   #18
BamaBob's Avatar
Originally Posted by Steve A View Post
Thanks! Is Camco ok? I am looking on Amazon.
Also what is the best to use for chemicals?
I assume these are all things they will go over when we pick up but I rather use what is best rather than what they peddle.
X2 on the Rhinoflex - buy NOTHING else. Cheap sewer hoses are a disaster waiting to happen
Check and make sure you do not have a water hookup for a black tank rinse.
a Great chemical system for black tanks is made by bluestreak.com
Finally, remember to NEVER keep the black tank valve open! Keep it closed until it's time to leave or the tank is over 3/4 full. Then dump black, rinse black, flush hose with gray tank water.
Nights Camped: 2013 - 242014 - 422015 - 56Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
Old 04-17-2015, 02:36 PM   #19
I put a gal. of water in both gray and black tanks after dumping. This way any debris left behind won't get a chance to harden and be very difficult to remove.
CNYCamper is offline   Reply With Quote
Old 04-17-2015, 06:09 PM   #20
Vince and Charlette's Avatar
I like the variety at Camping World, but they don't always have the best prices. Sooner or later you will learn that Wal-Marts across the nation have a section reserved just for RVers. They carry Camco, Dometic and other familiar names for a lot less than you could get elsewhere. Here is my black water story: (everybody has one) I told the family we had a limited amount of water in our holding tank, so flush the toilet with the minimum amount of water...BIG MISTAKE! What we ended up creating looked like one of the great pyramids. Thankfully, another camper told us a quick solution: at the first opportunity, dump in a 25 pound bag of ice, then resume driving. The back-and-forth action will help loosen the mess. And, be sure to use a good chemical additive after every black water dump and every few days if you don't dump.
2018 Berkshire 38A
Vince and Charlette is offline   Reply With Quote
black, newbie, tank
