04-16-2015, 09:19 PM
Newbie Alert: Dumping Black / Gray Tanks
Hello everyone!
I will be picking up my 2015 Prime Time Avenger 26BH on Saturday. We have our maiden voyage planned for the following Friday.
Prior to this we had a 206ltd pop-up so I never had to deal with a lot of things especially the Black Tank.
I have watched a few videos on it and these are the steps I have gathered but want to make sure I have the steps right.
Hook up the hose
Place hose in hole with weight of some sort on top
Open the Black tank
Then rinse through the toilet (I assume with flushing the toilet?)
Then close it again and fill the tank half way
Repeat till running clear
Close Black
Open Gray
Rinse hose
Put hose away
Is that about right? Any tips or tricks?
Thanks!
04-16-2015, 09:26 PM
Purchase a high quality sewer hose and a clear elbow so you can see if the water is running clear. The hose that the dealer will give you as a starter kit is poor quality and will not hold up.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
04-16-2015, 10:08 PM
Thanks! Is Camco ok? I am looking on Amazon.
Also what is the best to use for chemicals?
I assume these are all things they will go over when we pick up but I rather use what is best rather than what they peddle.
04-16-2015, 10:26 PM
Canadian Member
Get a RhinoFLEX sewer hose kit and an extension.
Amazon.com: Camco 39761 RhinoFLEX 15' Sewer Hose Kit with Swivel Fitting: Automotive
Also, Google "Geo Method" and use it to help prevent solids from sticking to the walls of the tanks.
Did your Avenger come from the factory with a black tank flush? If not you'll want either get a wand-type device to spray into the tank or get something like the Tornado.
04-16-2015, 10:33 PM
Also you MUST have a 90deg elbow on the discharge hose,these come in Many shapes and have threads or steps to fit the ground sewer pipe! Just ( Put the Hose in the Hole) will Not fly in 99% of C/G! Youroo!!
04-16-2015, 10:48 PM
If you buy the Rhino kit that itat linked to above it includes the 90 degree elbow that youroo talked about above.
I also recommend getting a device called a Flush King ( or similar). It attached to the drain and then your Rhino hose or whatever brand you get attaches to that. Then a water hose at the dump also attaches to it. It will allow you to back fill your tank quickly with water so you can get several flushes of the tank in a shorter period of time than trying to fill via the toilet to clean it out. The Flush King is clear so it takes the place of the clear elbow mentioned above. When several trailers are waiting at the dump, keeping things moving helps all.
One thing you can do while you are still at the campsite that will help at the dump is to fill your tank at least 3/4 full just before you leave for the dump if it is not already that full. It gives you a better dump when it has all of that load behind it.
04-17-2015, 06:22 AM
Hot is on the left, ship roles down hill, don't bite your finger nails...no wait a minute that is plumbing.
Black tank, flush then grey, then grey. Don't bite your finger nails.
I keep disposable gloves and a bar of soap in the tray. I also keep all my "sewer stuff" in one box.
Keep your cheap hose and get a connector. Every now and then you made need the extra length to dump somewhere.
Salt
2014 Silverback 29RE, 2014 Ram 2500 CC 4x4 Hemi 6.4 auto w/ airbags, B&W Companion. Saltwater boats and rum like any good pirate.
Lose the 2nd and the rest will follow.
04-17-2015, 06:30 AM
Canadian Member
Before you buy something like the Flush King, watch this video.
http://youtu.be/dfTd0Slt_cU
04-17-2015, 12:01 PM
I second the RhinoFlex and a flexible sewer hose support. The clear connection is also important to make sure you are flushing clear. Also, double check you close the black tank when hooked up at a campsite, never leave it open, and flush when 3/4 or more full.
DP
2013 Tracer 240 AIR
2014 Silverado 1500
04-17-2015, 12:02 PM
Depending on what chemicals you choose, most will tell you to put 1 gal of water in your tank or mix it like a ratio, whatever.....so you will never know from one to the other, how much water you have in your black tank....I pre fill a milk jug before going to the dump station, then once im done dumping, I drop 2 tablets and 1 gallon of water, that way on the way home it helps wash the tank a little bit and I don't forget either. I never have a stinky camper because I forgot
2014 2500 RAM Laramie w/Cummins Love this truck!
2003 3500 RAM w/Cummins 783649 miles, Pulled a lot of campers with her.
04-17-2015, 12:03 PM
And DON'T keep the valve to your blank tank open while at the campground thinking "stuff" will roll right through. Dried up tank in the summer full of "stuff" won't make for a pleasent experience
04-17-2015, 12:13 PM
Originally Posted by itat
X2!
definitely good info.
Jim & Evelyn
-2015 Ford F-350 XLT Dually
-2016 Prime Time Spartan 1242X
-2012 Harley Davidson Street Glide (his)
-2004 Harley Davidson Fatboy (hers)
04-17-2015, 12:30 PM
I would use more than I gallon. The pipes on the way to the shut off valve take almost a gallon depending on your trailer.
04-17-2015, 12:41 PM
We've never had any issues with our black tank (like the dreaded clog) and follow a few rules:
- Thick rubber gloves that come almost up to my elbow whenever handling the sewer lines.
- Using an old hose to stick into the toilet to fill it or rinse it. (Never use your drinking water hose)
- Never messing with the black tank at dumping stations. Always quick in and out as people are waiting.
- Never dumping the black tank unless it's almost full and NEVER leaving the valve opened when parked at a full-hookup. If we need to bug out and it's not full, we'll start the night prior by doing long flushings to get it filled up.
-After dumping it, put about a gallon in there with some disinfectant or detergent. (Simple Green is cheap and smells great.)
- When dumping, always dump the black tank first than the gray to flush out the line.
I always keep a package of baby wipes in my truck to clean up after doing just about anything...setup/teardown/sewer management.
Rick & Karen
(Retired USAF, MSgt)
Monument, Colorado
8-year Travel Trailer RVers
2013 Forest River Rockwood Ultra-Lite 2904SS
2014 Toyota Tundra Maxcrew SR-5 TRD 4x4 (with Firestone airbags in the rear)
04-17-2015, 12:42 PM
As some others have stated the Rhino hose is the way to go. I debated on if it was worth the higher price when we bought our 5er. Would not have anything else now. Ours was a kit with 2 10' hoses, the elbow and caps for the hoses. Have since bought the clear 45 elbow.
Steven & Tiffany
2015 Crusader 296BHS
2013 Chevy 2500HD LTZ CC Z71
Camp as often as we can
04-17-2015, 12:44 PM
StlClay
Strongly reccomend Thetford aqua-kem liquid. You can get 6 bottles (8oz) at Walmart very inexpensively. I pour a bottle in after each dump and flush a few times. This is the only stuff that cleans the sensors (which everyone says are a bad design) so the tank indicators actually show empty. I also agree with all who mentioned the clear elbow so you can check on the flow
04-17-2015, 01:44 PM
Always drain your black tank then your grey, that way the gray water flushes out the hose. Double check on the black tank flush, most of the new RV' have them. That is something that will help flush out the black tank. The flush king is great for breaking a plug at the valve. If the pipe doesn't go directing into the tank (travel trailer), but up (motor home and/or 5th wheel) you'll need the flush king with the extra valve on it.
Good luck
04-17-2015, 01:56 PM
X2 on the Rhinoflex - buy NOTHING else. Cheap sewer hoses are a disaster waiting to happen
Check and make sure you do not have a water hookup for a black tank rinse.
a Great chemical system for black tanks is made by bluestreak.com
Finally, remember to NEVER keep the black tank valve open! Keep it closed until it's time to leave or the tank is over 3/4 full. Then dump black, rinse black, flush hose with gray tank water.
Nights Camped: 2013 - 24 • 2014 - 42 • 2015 - 56 • Jul 2016 - Fulltime •
04-17-2015, 02:36 PM
I put a gal. of water in both gray and black tanks after dumping. This way any debris left behind won't get a chance to harden and be very difficult to remove.
04-17-2015, 06:09 PM
I like the variety at Camping World, but they don't always have the best prices. Sooner or later you will learn that Wal-Marts across the nation have a section reserved just for RVers. They carry Camco, Dometic and other familiar names for a lot less than you could get elsewhere. Here is my black water story: (everybody has one) I told the family we had a limited amount of water in our holding tank, so flush the toilet with the minimum amount of water...BIG MISTAKE! What we ended up creating looked like one of the great pyramids. Thankfully, another camper told us a quick solution: at the first opportunity, dump in a 25 pound bag of ice, then resume driving. The back-and-forth action will help loosen the mess. And, be sure to use a good chemical additive after every black water dump and every few days if you don't dump.
2018 Berkshire 38A
