Old 04-26-2015, 08:13 PM   #1
Newbie: Freshwater Tank Filling When City Water Hookup?
2015 Puma PT31BHSS. Some trips we have city water, some trips we have to use freshwater tank. Recently, freshwater tank has been filling up when we hook up to city water. What are we doing wrong?
David9683 is offline   Reply With Quote
Old 04-26-2015, 09:23 PM   #2
HONDAMAN174's Avatar
Probably nothing. Cycle your water pump- the check valve sometimes get stuck open
Just glad to get away
Old 04-27-2015, 03:25 AM   #3
Check thread called "Whats causing this" under plumbing, etc.
Papa GLS is offline   Reply With Quote
Old 04-27-2015, 05:58 AM   #4
Herk7769's Avatar
The check valve in your water pump is stuck open.
It is sometimes caused by draining your hot water tank through the low point drains instead of closing the bypass valves and draining it through the anode/drain port in the water heater. This causes bits of anode and/or calcium nodules to be left in the cold water lines when drained. When you de-winterize, incoming water can push that crud into your faucets (causing them to leak), toilet valve (not to flush), and the water pump check valve (preventing ot from closing).
To TRY to fix this:
Depressurize your lines and remove the city water hose.
Turn on the water pump and open a faucet.
Shut the faucet and turn off the pump.
Reattach the city water hose and see if you can hear air (or see water) coming out of the fresh tank overflow, still.
If that does not fix it you have two choices.
Replace the pump head or pump
Add an additional check valve on the pressure side (opposite the inlet filter) of the water pump.
Name:	Shurflo Pump IPB.jpg
HAM CALLSIGN - KC3FFW
Old 04-27-2015, 03:28 PM   #5
Thx for the responses! I'll try these ideas this weekend.
Old 04-27-2015, 07:45 PM   #6
I agree with the other folks, it is probably your check valve in your water pump. I had the same problem last week. I turned off my city water, and ran my water pump for about 10 minutes, cleared it up. However, I did buy an external check valve to put on if the problem reoccurs.
tomrob1161 is offline   Reply With Quote
Old 04-28-2015, 09:40 AM   #7
We have a switch for City or gravity. I didn't switch it back from gravity and overfilled the freshwater tank. Oops!!!!!!!!!! Twice!!!!!!!!!!
DrippingDuo
Chappy and Liz
Dripping Springs, TX
DrippingDuo is offline   Reply With Quote
Old 04-28-2015, 10:03 AM   #8
Herk7769's Avatar
Do you have a photo of your setup? Is this a motorhome thing?
Old 04-28-2015, 11:16 AM   #9
Will go to the trailer later and get a pic. Forest River, Cedar 1crfeek, Silverback 31RK.
DrippingDuo
Chappy and Liz
Old 05-04-2015, 08:44 AM   #10
That happened to me also and on a hunting trip water froze and water pump had a hair line crack and leaked by the check valve, I suggest changing the water pump and you will be done with the problem
jim-bob is offline   Reply With Quote
newbie, tank, water, water tank
