Old 09-21-2012, 06:37 PM   #11
DDC
DDC's Avatar
I use two twenty five footers, mostly only need one I like to use the 90 elbow to, I have never used a pressure regulator I have had more experience with too low a pressure in campgrounds.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is offline   Reply With Quote
Old 09-21-2012, 06:54 PM   #12
Herk7769's Avatar
I have 3 different regulators in my plumbing bag (including a 50 dollar adjustable one with a pressure gauge) and now use none. 99.9999% of the time; LOW pressure is the villain. Make SURE you have a good "newer" filter. Most campgrounds have well water and some are VERY silty.
HAM CALLSIGN - KC3FFW
Old 09-21-2012, 07:23 PM   #13
I never use a regulator and never will as most of the plumbing in the newer units is pecks and will handle a lot more pressure than any CC's will have.
2004 Sierra 330RL 5th Wheel
2002 Silverado 2500 Duramax 4x4
States I have camped in
lonewolf is offline   Reply With Quote
Old 09-22-2012, 05:38 PM   #14
My starter kit came w/ a Valterra Standard 40-50 psi water pressure guage. I'm sure this is one of the cheaps ones some members are warning against, but it also seems like some very seasoned campers are saying not to bother w/ it at all?? So confusing!!!
Mike & Allie
2013 Salem Hemisphere 272BH
2006 Ford F250
PBallie1602 is offline   Reply With Quote
Old 09-22-2012, 06:35 PM   #15
ironj's Avatar
i have a fancy one with a gauge and a cheapy camco....i usually just stick the camco one on, and i have rarely had issues with low pressure/flow....if the pressure aint worth a crap i take it off.....a lot of times its the filter that causes a lot of pressure loss tho...
honestly i am more concerned with if i have extra hose ends and mending supplies....i have had TWO hoses start leaking on me this year...and they were BOTH new!!! that is frustrating!! the only thing more frustrating than that is realizing you need 30ft of hose and you only have 25ft! LOL
2015 F350 Platinum Fx4 6.7 Diesel Dually. B&W turnover, B&W Companion, air bags and wireless controller.
2015 Heartland Road Warrior 420 Rt
2012 f250 Fx4 6.7 Diesel crew cab tinted n tuned
2012 lacrosse 318bhs touring- sold
ironj is offline   Reply With Quote
Old 09-23-2012, 05:45 AM   #16
where's the confusion ?
"some very seasoned campers" won't be the one re-plumbing your water supply lines should they burst - you've got it - use it (even if it's one of the "cheap ones")
seems like a no brainer.....Bill
Whisky is offline   Reply With Quote
Old 09-23-2012, 08:08 AM   #17
I used to have a ten foot hose that worked most places and I didn't have a lot of extra on the ground. I now carry two twenty fives. I always use my regulator, it will only lower pressure when the pressure exceeds it's rated capacity. Put the regulator on the hose bib rather than on your camper.
comfun1 is offline   Reply With Quote
Old 09-23-2012, 08:52 AM   #18
punkaccountant's Avatar
Telling a newbie that they may not need a pressure regulator is very bad advice IMO. I always use a pressure regulator. It doesn't hurt anything and it protects your lines from bursting. Do a search in this forum and you will find posts from folks who did not use one and the consequences. The advice in those posts from "seasoned campers" was to use a regulator.
http://www.forestriverforums.com/attachments/signaturepics/sigpic20864_3.gif
2013 Rockwood Mini-Lite 2306
2011 Ram 2500HD Hemi
punkaccountant is offline   Reply With Quote
Old 09-23-2012, 09:06 AM   #19
I'm definitely going to use it! I'm an overly cautious A type, I was more worried if my cheap starter kit one was good enough or if I needed to spend money on a better one. Two more weekends and I get to take the Dollhouse out for the first time!! Kids/football, jobs- pooh! Always ruining my fun.
Mike & Allie
2006 Ford F250
Old 09-23-2012, 09:58 AM   #20
I just use a Valterra standard pressure regulator. It states it is lead free which is important to us. I believe the Camco regulator stated it contained lead which is why I opted for the Valterra. I can spend more for more expensive ones that can be serviced but these have always worked for me. Get a couple because you will forget one at some point.
