Old 05-02-2015, 02:02 PM   #21
TURBS's Avatar
Funny mine hasn't leaked in 15 years.
Drained and flipped every trip.
TURBS
08 duramax tuned n modded, 32bhok Sabre
2015 camping "2 nights"
Old 05-02-2015, 10:35 PM   #22
Originally Posted by TURBS View Post
DO NOT open a hot water tap to purge the air from hw tank this could be detrimental advice.
Can you elaborate as to why?
Edit: Never mind. Saw explanation in later posts. Thanks.
Sent from my phone using Tapatalk.
- 1969 Coleman Williamsburg (with original canvas!)
- 2000 Coleman Mesa
- 2014 Shamrock 21DK
- 1999 Chevrolet Astro
- 2005 Dodge Durango Limited 4x2 5L V8 Hemi
- 2016 Ford F-150 SCrew Lariat 4x2 3.5L V6 Ecoboost
chriscowles is offline   Reply With Quote
Old 05-03-2015, 03:04 PM   #23
OK, I have to weigh in here. Never hook up your water hose until after you have flushed the local water line! Unless, of course, you like drinking spider guts. Flush out the spiders and rust from the local line (especially early in the season). Then hook up.
And, in case no one has made it perfectly clear...hooking up to "city" water does not fill your onboard water tank. That is a totally separate operation. You have a fresh tank fill, usually behind a small locked door.
Happy camping. Actually, happy RVing. Camping is something different.
wetland is offline   Reply With Quote
Old 05-04-2015, 07:56 PM   #24
Go to YouTube they have video on all of this....
The Outdoor Duffle Bag is offline   Reply With Quote
Old 05-04-2015, 08:13 PM   #25
Flybob's Avatar
Originally Posted by Bowhnter View Post
Opening a panel is not a problem, I just figure if I need into it each time, it is going to get a hinge. Getting to this one by the slide is not straight on access.
My tank is enclosed and do not see any way to look into it.
Also, I see a cord was left unplugged, I assume this is for electric heat and should have been plugged in.
You do not have to remove the panel each time. Only to winterize and de-winterize. Once set for normal operation, you are good for the season.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 05-04-2015, 09:35 PM   #26
Bowhnter's Avatar
Now that I have found the AC plug and plugged it in, the ac switch and pressure relief valve in the back outside I think I am good to go. I am hoping the tank was full all the time, because when I found the AC switch it was already on. You would think the dealer would make sure it was plugged on and the switch was off before sending it home with you.
Mike and Susan
Cavalier King Charles - Jack (4) and Sadie (3)
2015 Columbus 320 RS
2017 Ram 3500 6.7 Diesel
Bowhnter is offline   Reply With Quote
first time, newbie, water
