Old 11-11-2013, 09:02 PM   #11
Professional Curmudgeon
First, ensure your holding tanks are empty, then close the drain valves.
Then looking at your water pump, you should see a hose coming from the water tank to the pump and a hose not connected to anything going to the pump as well. There will be a valve at that 'T' fitting. Turn the valve so that the handle is in line with the tube that doesn't go anywhere. Stick that tube into your jug of antifreeze, turn the pump on, and it will start pumping anti freeze all through your camper. If you have elected not to bypass your water heater, go outside and hold the pressure relief valve open until you get solid pink coming out of it. Then go to each sink and open the faucet handle for cold and hot. Start with the sink closest to the pump. Leave the valve open until solid pink comes out, then close it. Go to the next closest one and repeat. Keep an eye on your antifreeze jug, that stuff will pump out fast. After the sinks are done, do the shower (don't forget the outside shower) and the toilet. Turn off your pump and remove the antifreeze jug. Pour about a cup of antifreeze into each sink and shower drain. Then pour some into the toilet without flushing. That will help your flange seals stay soft.
2002 Forest River Flagstaff 8528RLS
2014 Coachmen Catalina 253RKS
2016 Keystone Summerland Mini 1750RD
2012 F250 Lariat 6.2L Crew Cab FX4
wrvond is offline   Reply With Quote
Old 11-11-2013, 09:42 PM   #12
Iwannacamp's Avatar
Originally Posted by wrvond View Post
First, ensure your holding tanks are empty, then close the drain valves. Then looking at your water pump, you should see a hose coming from the water tank to the pump and a hose not connected to anything going to the pump as well. There will be a valve at that 'T' fitting. Turn the valve so that the handle is in line with the tube that doesn't go anywhere. Stick that tube into your jug of antifreeze, turn the pump on, and it will start pumping anti freeze all through your camper. If you have elected not to bypass your water heater, go outside and hold the pressure relief valve open until you get solid pink coming out of it. Then go to each sink and open the faucet handle for cold and hot. Start with the sink closest to the pump. Leave the valve open until solid pink comes out, then close it. Go to the next closest one and repeat. Keep an eye on your antifreeze jug, that stuff will pump out fast. After the sinks are done, do the shower (don't forget the outside shower) and the toilet. Turn off your pump and remove the antifreeze jug. Pour about a cup of antifreeze into each sink and shower drain. Then pour some into the toilet without flushing. That will help your flange seals stay soft.
Dang...you are good!!!
2017 Puma 297RLSS
2005 Ram 2500 4X4 diesel
Our new 5er 10-26-16
Old 11-12-2013, 08:05 PM   #13
buskirk21921's Avatar
Just another tip, to make sure to purge the fresh water inlet. Relieve some of the pressure in the system by opening a faucet and then go to the fresh water inlet and remove the screen from the fresh water inlet. Push on the white piece inside of the inlet which is spring loaded(valve) and let the antifreeze flow. People forget about this. See the attached winterizing site that I found.
Hope this helps.
Joe and Diane Buskirk
2015 Chevrolet Silverado 3500HD Duramax Diesel 4x4 SWD
2015 360IBL Coachmen 5th Wheel
"Camping is not just a past time it is my relaxing way of life"
buskirk21921 is offline   Reply With Quote
Old 11-16-2013, 05:17 PM   #14
Thanks everyone for the advice. Finally figured out where everything was and still nothing coming out of faucet. Finally gave up and took to rv repair to winterize and turns out the water pump wasn't working. Thank goodness still under warrantee!
munndl is offline   Reply With Quote
