Old 11-11-2013, 01:44 PM   #1
Newbie wInterizing an RV
Hoping for some winterizing advise. We have a forest river xlr and have never used the water heater or water pump. We only hooked up to park water one time and used one faucet and toilet. Is it necessary to do the full winterizing exercise or is it possible to just drain the black and gray tanks?
munndl is offline   Reply With Quote
Old 11-11-2013, 01:49 PM   #2
realebill's Avatar
if you hooked up to park water,then you have water in your lines to the sink,vanity tub and toilet.also ,unless your w/h bypass was on,you will have a water heater full of water.
2008 rockwood signature ultra lite 8315SS[SIGPIC]
realebill is offline   Reply With Quote
Old 11-11-2013, 02:21 PM   #3
rskrbina's Avatar
Being around Ft. Worth, I would fully winterize. It's been known to freeze in that part of Texas.
Rudy and Jenny
2014 Flagstaff V-Lite 28WRBS
2013 F-150 Eco-boost 3.55
rskrbina is offline   Reply With Quote
Old 11-11-2013, 04:18 PM   #4
markb5900's Avatar
Yes you need to fully winterize it.
Being hooked up to park water is the same as using your pump for winterizing purposes.
Don't forget to drain your freshwater tank also. Even if you didn't put water in it, the dealer probably did to test the pump etc..
Mark B
2015 32 Foot Rockwood 8289WS 5th Wheel
2017 GMC 3/4 Ton TV
markb5900 is offline   Reply With Quote
Old 11-11-2013, 04:53 PM   #5
Thanks for the advise! So now I need to know if the bypass valve to the water heater was on or not. Where is that located? Is that on the outside panel or would it be under the sink?
Old 11-11-2013, 04:59 PM   #6
markb5900's Avatar
On my Cruise Lite it is under the sink. There are actually three valves. you close the two going to the water heater and open the one that then bypasses it.
Once you see it, you will see what I mean.
Mark B
2017 GMC 3/4 Ton TV
Old 11-11-2013, 07:14 PM   #7
No luck finding any kind of valves. Looked under sinks, under bed and outside.
Old 11-11-2013, 07:46 PM   #8
You can tell where your water heater is on the outside. Figure out where that is on the inside. It's got to be there somewhere.
Old 11-11-2013, 08:17 PM   #9
I have unscrewed every panel remotely near the water heater and nothing. Is it possible to pump the antifreeze in without bypassing the water heater? I know it will use more...
Old 11-11-2013, 08:56 PM   #10
Professional Curmudgeon
Your bypass valves are going to be on the backside of the water heater itself.
Yes, you can winterize by filling the water heater with antifreeze, but nobody likes doing that. It'll use 6 gallons of anti freeze in the water heater alone.
It is possible that your camper did not come with a water heater bypass installed, though that is rather rare these days.
Once you find the backside of the water heater, ensure that you can see one water line going into the cold fitting (bottom) of the water heater, and one water line coming out the hot fitting (top), with no connecting line between the two lines with one or more valves in the circuit.
If you establish that you do not have a bypass kit installed, I'd recommend purchasing one and installing it yourself, then winterizing. They really aren't that hard to install.
2002 Forest River Flagstaff 8528RLS
2014 Coachmen Catalina 253RKS
2016 Keystone Summerland Mini 1750RD
2012 F250 Lariat 6.2L Crew Cab FX4
wrvond is offline   Reply With Quote
