Old 12-28-2010, 11:16 AM   #1
Newbie winterizing questions!
Hey guys, first poster here thanking you all for your knowledge in advance!! I have questions about winterizing. I am in NC, where it may get cold at night, but stays plenty warm during the day (above freezing) most of the time during winter. Am I okay to keep our trailer normal (without winterizing the lines) if I leave the heat on turned low, around 55? My dealer said this would be more than sufficient to keep the lines open with no problems, even if it drops below freezing. We want to keep it ready to camp at any time. For example, we have about four inches of snow on the ground right now (abnormal here, to be sure), but it is supposed to be 65 this weekend!! Thanks Mother Nature!
It is on power all the time when at home, which leads to my second question. Should my heat work with power alone, or only with LP on? I'm sorry if that is a stupid questions, I just don't know.
We have a 2009 Shamrock 21SS, by the way. I know that question was coming. Thanks!!
sappito is offline   Reply With Quote
Old 12-28-2010, 01:34 PM   #2
bikendan's Avatar
welcome to FRF! can't help you with winterizing, since i live in California.
just know that winterizing is needed if you have extended days of freezing, without any times above freezing.
but, be sure to visit the Expandable section here, including one for Shamrock owners.
lots of help and info on owning a hybrid trailer.
Old 12-28-2010, 02:10 PM   #3
grhodes50's Avatar
First of all to the forum!
Your furnace will work without being hooked up to shore power, but will drain your battery very quickly. Probably overnight depending on how much it runs of course.
Keeping the tt hooked up to shore power will not hurt anything except keep an eye on the battery and make sure you don't boil it dry.
The furnace does supply some heat to the underbelly which should easily keep your tanks and lines from freezing in the temps you described. You will be using a lot of propane though.
I am green with envy that yopu don't have to winterize and can camp year round! So enjoy that tt for the both of us!
Gary & Trish
2018 Nights Camped - 5
Old 12-28-2010, 02:29 PM   #4
But the LP needs to be on, in any case, right? I cannot heat the TT with power alone, or am I doing something wrong? Thanks!!
Old 12-28-2010, 02:31 PM   #5
MtnGuy's Avatar
You are correct, you need your LP on.....the furnace runs on LP gas and uses 12 volts for the fan, plus 12 volts for the ignition.
If you have an enclosed underbelly and floor ducts for the furnace, then that should help to keep the lines there from freezing. The only problem there is the pipes sticking out of the underbelly. The hot and cold water drains, fresh water tank drain, and waste tank drains. I use rope lights in these areas when I have not winterized to keep those pipes from freezing and bursting.
Old 12-28-2010, 02:36 PM   #6
The LP must be on for the furnace to operate. The furnace burns the LP to get heat, and uses a 12 volt fan for the blower. That means you need LP, (and lots of it) and a 12 volt battery for the furnace to work. You could use a tank of LP or more per week, and your battery needs to stay charged daily. The battery will stay charged by leaving the trailer plugged in. The LP tanks will you have to check often.
Now with that said, and not sure where you are in N.C., you might could put a small electric heater in the camper and have sufficient heat.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 12-28-2010, 03:03 PM   #7
grhodes50's Avatar
I thought about the electric heater myself, but am I right in thinking he probably needs to run the furnace to keep the underbelly heated?
Gary & Trish
Old 12-28-2010, 03:40 PM   #8
bikendan's Avatar
i think an electric ceramic heater will keep the lines inside warm enough.
the tanks below have room for expansion unless they are close to full.
i think the '09 21SS has its FW tank inside. i have an '07 23SS and my FW tank is inside.
only the gray and black tanks are exposed underneath.
so if the FW tank is inside, keeping the ceramic heater going inside should keep everything warm enough.
again, this opinion is from the many posts i've read, not from real-life experience.
and yes, the furnace requires propane to heat the trailer and will run the battery down fast if not hooked up to shore power.
Old 12-28-2010, 03:48 PM   #9
grhodes50's Avatar
Sounds good to me.
Just thought about the water lines going into and out of his water heater, depending on it's location of course. One tt I had the water tannk was not accessible from inside the tt. Might use mtnguy's suggestion of rope lights for those if need be.
Gary & Trish
Old 12-28-2010, 03:53 PM   #10
If it is parked at home with empty tanks, no need to heat them. He is a new poster, just hope he understands to dump the tanks when leaving the campground, or somewhere on the way home.
I am in Winston-Salem, NC, and we have have had as many 4 days in a row where the high didn't get to the freezing mark. For my 2 cents, antifreeze is cheaper than plumbing repairs. Also , a lot of the campgrounds in the are turn off the water in the winter. For us, we'll stay home by the fire, with the camper winterized.
LadyWindrider
winterize
