Old 11-14-2019, 08:46 PM   #1
Blessed old folks
Zhairdzinr's Avatar
Newbie with a water issue
Itís the evening the dealership is closed,
Brand new Geo Pro 19fd thank God we are still home... But suppose to leave on first trip in a couple days!
Emptied the fresh water tanks that the deal put their water in. We put in the manufactures water filter as directed. Refilled with clean new hose with new extra water filter attached.
Now with fresh water tank at 2/3 full with pump on water spits out for about 2 mins. Then stops tuning all together?????
Zhairdzinr is offline   Reply With Quote
Old 11-14-2019, 09:26 PM   #2
Georgia Rally Coordinator
aceinspp's Avatar
Welcome to the forum. You might check to see by the water pump if there is a valve to turn that is used to winterized may be turned wrong. Later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10 gear
Days camped 2017 62
Days camped 2018 67
Days camped 2019 62
Old 11-14-2019, 09:46 PM   #3
Flybob's Avatar
If WH was empty it can take a few minutes until it fills and water begins to run again. Also check to see there is no air leak on water filter housing.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 11-14-2019, 10:07 PM   #4
Blackrock's Avatar
There are a lot of lines to get primed plus the 6 gallon water heater. I would hook my hose into the city water connection and open all the faucets until everything stopped burping. Then turn off the water hose and see how the pump works.
2016 RAM 1500 - 2016 Keystone Laredo 265SRK
The road goes on forever and the party never ends.
Blackrock is offline   Reply With Quote
Old 11-14-2019, 10:25 PM   #5
bubbles's Avatar
If the previous inputs don't help pull the faucet aerators to see if they might be clogged.
Old 11-14-2019, 11:18 PM   #6
Blessed old folks
Zhairdzinr's Avatar
Thanks that is where we are at. Continued to be the same . Works ok on city connection. It is when we disconnect and use the tank.
Old 11-15-2019, 12:48 AM   #7
Just before the pu be a small screen filter. If the cover is loose or the oring is not seated it will suck air and have a hard time priming.
Be sure that the valve to the something house is not open.
MtBiker is online now   Reply With Quote
Old 11-15-2019, 11:36 AM   #8
Blessed old folks
Zhairdzinr's Avatar
We want to Thank “Fred” in Technical Support at Forest Riverr for his help this am Drum roll for the Newbies overlook!!!!! OPEN WATER MISER VALVE IN The SHOWER.
Thank you for all the awesome support from all of you!! We tried and look at each and everyone of those issues overnight and this am.
Old 11-15-2019, 01:49 PM   #9
tc cruiser's Avatar
Thanks for posting back. I have the same water miser in my shower. Never thought it could cause this.
TC
2018 Flagstaff E-Pro 19 fbs
tc cruiser is offline   Reply With Quote
Old 11-23-2019, 10:18 AM   #10
Water Miser valve?
Where is this, or can you post a pic?
I'm newer than you are!
1981Dawg is offline   Reply With Quote
Old 11-23-2019, 12:31 PM   #11
NMWildcat's Avatar
I'm confused. The water miser valve is usually between the shower hot valve and the shower head. So for it to be engaged at all, your shower valve would have to be open also. Same on the sink miser device. And it shouldn't matter if you were on pump or city pressure, the valve would act the same (divert water to fresh tank instead of shower head).
Just trying to understand, and wondering if your factory installed shower miser is plumbed differently from mine.
Scott and Liz - Southern NM
Old 11-23-2019, 01:17 PM   #12
NMWildcat's Avatar
Okay, been thinking more about this. Your return line must be plumbed right behind the pump on the suction side. So when you are trying to prime the pump with the miser valve in the wrong position, the pump is drawing in air from the shower Miser return line instead of pulling only from the fresh tank?
My miser return line is plumbed to the top of the fresh tank, so for us, it doesn't matter what position the miser valve is in until we open the shower valves. The pump always draws only from the tank, instead of the return line and the tank.
Make any sense? Maybe I answered my own question
Old 11-23-2019, 01:44 PM   #13
Head Rambler
X2
Mine is plumbed so that you'd have to have the shower valves open and the miser valve closed in order to affect the flow and/or temp.
Gotta go campin!
newbie, water
