As mentioned, most all of us fill the fresh water tank by watching for water to come out the overflow hose and not by watching the indicator lights. (which are incredibly inaccurate)
My only CAUTION of filling the fresh water tank by watching for water to come out the overflow tube, is to fill the tank slowly. Often times the overflow hose is not of the same size/capacity as the method used to fill the tank. With sufficient pressure/flow, you can run the risk of filling the tank too quickly and ballooning the tank, causing damage to the tank, the brackets holding the tank and/or even bulging the floor upwards in the R/V. Because of this, I would caution against the "stick the hose in and walk away method."
One other word of caution... some overflow hoses are plumbed without a sufficient way of keeping the overflow of water from siphoning the tank empty. We've had more than one report here where the fresh tank was filled until water came out the overflow and by the time they got to camp, it was empty. You'll need to be sure once a gallon or two comes out the overflow (when filling) that it then stops running out.
Once you've filled the tank a time or two watching for these things, you'll be an old pro at it.
Days Camped: '16=46 ☼ '17=30 ☼ '18=51 ☼ '19=53
