Old 04-20-2016, 07:22 PM   #11
Originally Posted by ov845 View Post
Hope this helps.
Attachment 105572
Happy Camping!
2012 Ram 1500 Crew Cab 5'7" Bed
Engine 5.7L Gear 3.92
Airlift 1000
2015 2809W Windjammer (Diamond Package)
Husky Centerline WDH
As soon as I saw your diagram I knew what the problem was. Thank you.
KB
rollingroo is offline   Reply With Quote
Old 04-21-2016, 05:25 PM   #12
ov845's Avatar
No problem! Have fun!
Happy Camping!
4 X 4 Engine 5.7L Hemi Gear 3.92
Airlift 1000
ov845 is offline   Reply With Quote
Old 04-29-2016, 08:45 PM   #13
while getting my grey wolf 19rr toy hauler ready I don't have any hot water to my kitchen faucet , shower and bathroom sink I have hot water but nothing on hot water side of kitchen faucet
bradley 0261 is offline   Reply With Quote
Old 04-29-2016, 08:53 PM   #14
northstar1960's Avatar
I assume you get nothing no hot or cold water from the hot side but you do have cold water on the cold side in the kitchen faucet ? correct if so then you have a kinked line or blockage . check the angle stops under the sink and make sure there on .
northstar1960 is offline   Reply With Quote
Old 04-29-2016, 09:42 PM   #15
From the sink to the floor there is no visible kinks or valves and every thing under trailer is sealed , I don't see how it could be plugged bought it new and only used it a few times, guess I'm going to have to take the insulation off the bottom , thank you for the help
Old 04-29-2016, 09:56 PM   #16
Assuming the cold side works and it's just the hot water . you either have a blockage which is not unusual on a new unit or the line is kinked somewhere . did it work before it was winterized ? there could have been a partially kinked line that over the winter and cold closed off completely . maybe the faucet cartridge for the hot is clogged with construction debris . Start with the easiest thing and work your way to the oh **** thing
Old 04-30-2016, 12:11 AM   #17
MNtraveler's Avatar
Before going to that difficult work, I'd suggest removing the HW line to the faucet and see if you can get any water flow through the line itself. (Use a bucket...) That will tell you if the obstruction is further upstream or if it might be in the faucet itself.
Even though new, there's plenty of chances for construction debris to clog the line or the faucet. Shouldn't happen but it is frequently reported here.
If it's in the faucet you might be able to back-flow (or back-blow) it out towards the input side. If not, you may have to disassemble and see where it is. Catch everything that comes out in a bucket or in the sink itself so you'll know when you have caught the culprit!
Good luck!
2016 Forester 2401R
MNtraveler is offline   Reply With Quote
hot water, water
