Old 05-11-2016, 08:39 AM   #11
Pickin' & Campin'
Do you have any water at all coming from the hot faucet.
You mentioned in your original post... "nothing comes out of the tap".
Maybe it isn't a water heater problem.
Days Camped: '15=22 '16=46 '17=30 '18=4
Old 05-11-2016, 08:41 AM   #12
Oakman's Avatar
If you have the valves correct on the water heater then it must be something else. Not all RV's are made the same so before this becomes a big guessing game why don't you tell us what brand of RV and floorplan you have.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is online now   Reply With Quote
Old 05-11-2016, 08:43 AM   #13
Pickin' & Campin'
First sentence of first post... "So I have a brand new 31fqsl..."
Old 05-11-2016, 08:47 AM   #14
TURBS's Avatar
We've seen before, one of the valve handles turn open and close however the valve inside didn't move.
I'm going with that.
You checked for water coming out of tank but not for water on the other side of the valve.
2008 2500hd Duramax
2015 Columbus 320RS
2016 nights camped "5"
2015 nights camped "34"
Old 05-11-2016, 08:50 AM   #15
On my unit there is an antifreeze port with a valve. could that valve being on or off have something to do with this?
Marty
2016 Rockwood 2703WS Sapphire
2011 F150 Ecoboost SCAB/3.55
Martsing is offline   Reply With Quote
Old 05-11-2016, 09:07 AM   #16
Pickin' & Campin'
Marty
Likely not. The OP stated he's tried it on city water and the internal pump, neither which have made a difference.
The valve you refer to would keep the internal pump from supplying water to the system (if turned towards the antifreeze port) but would have no effect when hooked to city water.
Old 05-11-2016, 09:10 AM   #17
Oakman's Avatar
So what brand is a 31fqsl?
Bob and Joyce
ATU Local 788
Old 05-11-2016, 09:11 AM   #18
Head Rambler
Does no water at all come out or is it just cold when it comes out?
Does water come out of the cold side?
If it does is it hot or cold?
Gotta go campin!
Old 05-11-2016, 09:12 AM   #19
Pickin' & Campin'
Forest River.
Google is your friend....
*31FQSL*
Old 05-11-2016, 09:30 AM   #20
Its a XLR Nitro 31fqsl. Cold water works, and when I open the bypass and try the hot water handle, I get cold, so it is flowing. Once I turn off the bypass, I get absoultly nothing for hot, and cold still works
Po Po Pork is offline   Reply With Quote
hot water, water
