Old 05-11-2016, 11:31 AM   #31
Did you have hot before or is this the first time you used, it sounds like the check valve at top of tank is frozen or backwards.
Dale & Karen
2015 Lacrosse 311RLS
2006 F-250 The 06-6.0
Dwilcox is offline   Reply With Quote
Old 05-11-2016, 11:41 AM   #32
AquaMan's Avatar
This mystery has been solved.
Open bypass = Gets water to tap
remove line from tank = hot water comes out
There is a valve and 6" of line that won't allow water to flow.
Clean or Replace valve, it's either clogged or broken.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 05-11-2016, 12:18 PM   #33
TURBS's Avatar
What do I win?
2008 2500hd Duramax
2015 Columbus 320RS
2016 nights camped "5"
2015 nights camped "34"
Old 05-11-2016, 12:27 PM   #34
BooBoo23's Avatar
You beat me to it, that was going to be my next guess. If it is like my RV with only 2 valves on the bypass and a check valve on the tank outlet the check valve may be installed backwards.
2014 Palomino Puma 25RS
2011 F-150 Super Crew XLT
Days camped in 2014 - 23 Camped 2015-47
Camped 2016-71, 2017-33, 2018-29 booked
BooBoo23 is offline   Reply With Quote
Old 05-11-2016, 01:12 PM   #35
AquaMan's Avatar
But, the OP stated that he removed the line from tank and hot water came out. Hot water would not flow out if check valve was installed backwards.
Old 05-11-2016, 01:14 PM   #36
Who Dares, Wins
doc73's Avatar
Hmm.. Good point. Was the valve still attached when the water flowed?
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 05-11-2016, 01:14 PM   #37
TURBS's Avatar
Which is why I said in post 14 he needs to check for water right after the hot side valve.
Old 05-11-2016, 01:23 PM   #38
AquaMan's Avatar
Exactly.
Old 05-11-2016, 01:31 PM   #39
AquaMan's Avatar
He would have had to of taken the line off first, then the check valve.
Old 05-11-2016, 01:33 PM   #40
Who Dares, Wins
doc73's Avatar
Off topic, but do all water heater have a check valve? See,s to be a bunch of folk here that have had the lines reversed that theoretically would mean they should have no water but do?
2015 ChevyHD D-Max
hot water, water
