Old 05-11-2016, 01:53 PM   #41
Kaadk's Avatar
No hot water
Originally Posted by doc73 View Post
Off topic, but do all water heater have a check valve? See,s to be a bunch of folk here that have had the lines reversed that theoretically would mean they should have no water but do?
Mine doesn't. During my changing out of my valve (see post a few above) after all said and done I turned the water back on and ended up backfilling about 1/3 of the tank from the top before I remembered I had closed the bottom valve before draining the tank earlier.
Edit: forgot to mention the bypass valve was also open.... I was trying a lot of things that day.
Old 05-11-2016, 01:55 PM   #42
Who Dares, Wins
doc73's Avatar
Ok thanks, I did not think mine did either.
Sent from my SM-G930V using Tapatalk
2015 Chevy HD D-Max
2022 Impression 315MB
doc73 is offline   Reply With Quote
Old 05-11-2016, 02:44 PM   #43
Atwood water heaters have a check valve, Suburban water heaters do not.
Atwood's winterize utilizing a 3-way valve and the check valve, Suburban's utilize the three valve setup.
Gotta go campin!
Old 05-11-2016, 02:57 PM   #44
wmtire's Avatar
Bama, as many of these water heater threads as I have been involved in, I haven't really found that to be the case in my experiences. It depends on how the manufacturers plumbed the water heater and how many valves they used for the bypass operation. They can use either one, two, or the three valve system. The one valve systems (and some of the two valve) usually involve some kind of internal check (aka backflow preventer) valve being utilized, whereas the three valve system doesn't need such.
I was just involved in this thread a few weeks ago, where the member had a Suburban water heater and only one bypass valve. The way this system is setup, is that when you open the bypass/crossover line, it closes the cold water inlet at the same time. There is an internal check valve installed in the hot water outlet, that prevents water backflowing into the water heater.
Here is the thread I am referring to, that has some good member pics.
http://www.forestriverforums.com/for...er-106710.html
It sure would make it easier on us and offering advice if there was a consistency in the plumbing across all RV model and/or water heater brands....but I just haven't find such yet.
2011 Flagstaff 831 RLBSS
Old 05-11-2016, 03:22 PM   #45
BooBoo23's Avatar
As Wmtire stated, it probably depends on the manufacturer as to how it is plumbed. I have a Palamino with a Suburban WH and they used a check valve on the WH outlet.
2014 Palomino Puma 25RS
2011 F-150 Super Crew XLT
Days camped in 2014 - 23 Camped 2015-47
Camped 2016-71, 2017-33, 2018-29 booked
KT4W
BooBoo23 is offline   Reply With Quote
Old 05-11-2016, 03:31 PM   #46
Kaadk's Avatar
Well, it makes sense that it's up to the trailer manufacturer on how they plumb the lines going to the water heater, but wouldn't it be up to the water heater manufacturer whether or not the water heater had an internal check valve?
Old 05-11-2016, 03:37 PM   #47
AquaMan's Avatar
Not really, the RV manufacturer does the plumbing, the check valve is there only for the instance that the manufacturer needs it for. Really has nothing to do with making hot water.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
Old 05-11-2016, 04:45 PM   #48
wmtire's Avatar
Mike, all of the check valves I have seen are plumbed at the hot water outlet, but not internal to the water heater itself. They are only internal to the water line/fitting.
Old 05-11-2016, 04:55 PM   #49
Georgia Rally Coordinator
aceinspp's Avatar
In the last 4 campers I have had they all had the 3 valves and only one is turned in summer to get hot water. No check valves. Later RJD
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
Old 05-11-2016, 05:48 PM   #50
Kaadk's Avatar
Ahh, now I know. I always thought they were internal to the tank. (Not having had one myself.)
External ones then are really nothing more than a valve you don't have to turn and can be easily replaced by a valve if needed.
Old 05-12-2016, 11:04 AM   #51
I stand corrected! :|
Of all the water heaters I've seen, all the Atwood's have had the 3-way/check valve setup and all the Suburban's have had the three individual valves. Luck of the draw, I guess.
Gotta go campin!
Old 05-16-2016, 09:35 AM   #52
Well I got it figured out. It was a bad elbow that was on the hot line. On mine, the hot comes out the back, has about a 15 inch run then makes a turn under my cabinet before the check valves. I cut the line out and replaced the elbow and now have hot water running. Thanks everyone for the suggestions!
Po Po Pork is offline   Reply With Quote
Old 05-16-2016, 09:57 AM   #53
Had same problem, with the three valves AND a check valve on the hot side. The valve had come apart and the moving stem inside the valve body had come loose from it's keeper and the stem blocks water flow in the forward direction. Pull the "out" connection and see if that's the problem.
safetychain is offline   Reply With Quote
Old 05-16-2016, 09:08 PM   #54
wmtire's Avatar
Glad you got it all solved and thanks for reporting back with the solution. That will helps others in the future.
I don't suppose you took pics of the bad part, did you?
Old 05-17-2016, 06:54 AM   #55
AquaMan's Avatar
Kinda wondering myself, how an elbow is bad, unless during the molding process the internal mold slides didn't seal off against each other creating the opening.
hot water, water
