Old 05-10-2016, 10:25 PM   #1
No hot water
So I have a brand new 31fqsl. Got it home and on the first trip, no hot water. Water heater fires up fine, but nothing comes out of the tap. I have tried every combination of valves etc near the heater. The water heater has hot water, but I can't get it to flow out of it. Any suggestions would be appreciated
Po Po Pork is offline   Reply With Quote
Old 05-10-2016, 10:35 PM   #2
BooBoo23's Avatar
The valves on the back side of the WH are still in the winterized position. There are either 2 or 3 valves. Turn the valve on the input side of the WH to allow flow in (usually the bottom valve) and the turn the valve on top to allow water to flow out (sometimes there is a check valve like mine, rather than one that turns) and turn the valve on the line between the in and out lines to block the flow of water. I'm sure WMtire will post a diagram. AND, IF the valves are in the winterized position you most likely don't have any water in the tank so do not turn on the electric heater.
2014 Palomino Puma 25RS
2011 F-150 Super Crew XLT
Days camped in 2014 - 23 Camped 2015-47
Camped 2016-71, 2017-33, 2018-29 booked
KT4W
BooBoo23 is offline   Reply With Quote
Old 05-10-2016, 11:24 PM   #3
The tank is full and I have hot water when I use the pressure relief valve, I'm just not getting it through the lines
Old 05-11-2016, 05:11 AM   #4
fonzie's Avatar
here is how the valves should be set up for use....
Fonzie
Nights Camped:2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42)
Old 05-11-2016, 08:00 AM   #5
That is how I have everything, the water heater fills up fine, fires up fine, but nothing will come out. I have disconnected the hot line coming out of the back and hot water comes out but not when its called for at the faucet.
Old 05-11-2016, 08:16 AM   #6
rattleNsmoke's Avatar
It's bound to be in the valve positioning as the OP stated. The second season I had The Beast, I found out the costly way by paying a rolling RV repair guy $20 to show me the bypass valve was turned the wrong way....
rattleNsmoke is offline   Reply With Quote
Old 05-11-2016, 08:24 AM   #7
wmtire's Avatar
I would doublecheck the positioning of the valves as others above have stated. it's easy to confuse the way the handles are turned (as if they are in the open or closed position). We keep this sticky link below at the very top of this subforum you are posting in, just for this common problem. It may help too, and explains the valve handle positions in more detail.
http://www.forestriverforums.com/for...st-103381.html
Now it is entirely possible to get a bad valve, and when you turn the handle, it's not actually turning the valve inside. We've had that happen before. You should be able to kind of feel if this is the case as the handle should turn a lot easier than the other ones.
2011 Flagstaff 831 RLBSS
Just imagine, for a moment, if there were no hypothetical situations.
Old 05-11-2016, 08:33 AM   #8
Thanks everyone, I have checked, double checked and checked again, and I am almost 100 percent sure I have the valve's in the correct position, but I'll try again.
Old 05-11-2016, 08:35 AM   #9
wmtire's Avatar
OK, I know this sounds crazy, but are you connected to a city water supply with a hose...or are you trying to draw water from your onboard tank via a pump that must be turned on?
Old 05-11-2016, 08:38 AM   #10
I tried with both tank water and city water connection to rule any other issues out.
hot water, water
