Old 10-10-2015, 11:46 AM   #1
No Hot Water - Now I'm in hot water with the bride
brand new Rockwood Windjammer 3006wk and the hot water heater only warms water to lukewarm temp. Water heater switch is on, bypass is open and the gas lighter works. Is there a thermostat that I can increase the temp? what am I missing?
BixbyCamper is offline   Reply With Quote
Old 10-10-2015, 11:53 AM   #2
fonzie's Avatar
Close winterizing by-pass at water heater....see below middle valve needs to be closed
Fonzie
Nights Camped:2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42)
Old 10-10-2015, 11:54 AM   #3
nomad297's Avatar
Bypass should be closed. Also, make sure the knobs for your outside shower are turned off. If they are turned on and the button is turned off on the head, the hot and cold water will mix.
Bruce
Old 10-10-2015, 12:03 PM   #4
The operating manual says to operate the water heater with the bypass value open? contrary to your advice...can you explain for me please
Old 10-10-2015, 12:11 PM   #5
Ford Idaho's Avatar
With the bypass open you are mixing cold water with hot before it even makes it to the tap.
The bypass must be closed are the others have posted.
Old 10-10-2015, 12:30 PM   #6
BooBoo23's Avatar
Depending you your winterizing setup you could have either 2 or 3 valves for bypass. The valve that goes between the hot and cold lines must be closed unless you are going to winterize. In that case you need to close the other valves and open the bypass to prevent filling the WH with antifreeze. Should be just like the photo for normal hot water use.
2014 Palomino Puma 25RS
2011 F-150 Super Crew XLT
Days camped in 2014 - 23 Camped 2015-47
Camped 2016-71, 2017-33, 2018-29 booked
KT4W
BooBoo23 is offline   Reply With Quote
Old 10-11-2015, 01:09 PM   #7
Don't know which valve your manual is referring to - but look at the picture of the rear of the hot water tank. The middle valve must be closed. Otherwise you are letting cold water go into the tank and you are letting cold water bypass the tank which now mixes with the hot water coming out of the tank into your rig.
ottawapaul is offline   Reply With Quote
Old 10-11-2015, 02:05 PM   #8
bikendan's Avatar
Don't know what "operating manual" you're talking about but it's wrong.
Equalizer WDH
Old 10-11-2015, 05:47 PM   #9
Tom48's Avatar
Ditto
Tom48 is offline   Reply With Quote
Old 10-12-2015, 03:58 PM   #10
nomad297's Avatar
People come here, they ask for help, they get it and we never hear from them again.
It would be nice to know what the problem and solution were.
Bruce
hot water, water
