Old 08-04-2014, 11:37 AM   #1
Rugged Brown's Avatar
No hot water on electrical side
To date I have replaced the hot water element, and troubleshooted the the water heater plug in and still no hot water from the electrical side. Propane works well. I'm searching for ideas.
I'm sure all the brains converging on Goshen can fix this one for me.
Terry/Bernadette
Lily the Yorkie
2015 Dodge Ram Sport 1500
2015 Crossroads Zinger ZT28BH
Rugged Brown is offline   Reply With Quote
Old 08-04-2014, 01:56 PM   #2
KyDan's Avatar
About all that's left is the on/off rocker switch found near the burner tube and
the thermostat/hi limit which are located behind the rubber cover located somewhat
above the burner tube. These are labeled in the FAQ on how to change the element.
If the switch is bad or off OR the thermostat is bad or needs to be reset- these
will stop the electric side from heating.
Have you tried pushing the reset "buttons" found behind the black rubber
cover above the burner tube?
There are 2 places that say press to reset.
One side is the electric side and the other is the LP gas side.
I can't tell you which is which other than to say my 08 model the left side was
the 120v electric side.
IF the fusable link is burned out you can see that but you need to remove the
rubber cover first.
Be SURE to shut off power or unplug your trailer from shore power before
removing the rubber cover.
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 08-04-2014, 06:59 PM   #3
It's not the rest buttons. Those are working fine. I removed the cover to see what it was resetting and it was not tripped. I also removed the rocker on/off switch and will replace it with a new one tomorrow, if I can find one at the local rv dealer.
Terry/Bernadette
Lily the Yorkie
Old 08-04-2014, 07:49 PM   #4
doodler's Avatar
Have you checked your breaker in the inside panel to see if your getting 120v? Or if it is tripped?
doodler
doodler is offline   Reply With Quote
Old 08-04-2014, 08:22 PM   #5
Not tripped. I'm getting AC power to outlet.
Terry/Bernadette
Lily the Yorkie
Old 08-04-2014, 08:31 PM   #6
doodler's Avatar
Sorry. I missed that in the first post.
doodler
Old 08-04-2014, 08:41 PM   #7
wmtire's Avatar
Rugged, check out post #6 from this forum (and the rest of the entire thread). Your hi temp t-stat could be burned out. It acts like a fuse and when it burns out, you have to replace it.
Very common occurance
No Hot Water 2011 V-Lite 21WRS
Of course, all of this advice is under the assumption you have a Suburban brand water heater.
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 08-05-2014, 08:19 AM   #8
you know what, i took that plastic cover off last night and it looked fine. When i go home today, I will have another look at it, but I am not hopeful that is the problem. I removed the on/off switch and will replace that.
I will report back my findings.
edit: I do have the suburban water heater.
Terry/Bernadette
Lily the Yorkie
Old 08-05-2014, 08:44 AM   #9
Originally Posted by Rugged Brown View Post
you know what, i took that plastic cover off last night and it looked fine. When i go home today, I will have another look at it, but I am not hopeful that is the problem. I removed the on/off switch and will replace that. I will report back my findings. edit: I do have the suburban water heater.
Put a meter on it, might look good but it could be defective. You've ruled out everything else.
Old 08-05-2014, 01:33 PM   #10
PROBLEM SOLVED
Replaced rocker on/off switch and voila, we have hot water. Thanks for the tips in the right direction.
Terry/Bernadette
Lily the Yorkie
electric, electrical, hot water, water
