Old 09-02-2016, 07:44 PM   #1
No Hub clamps
Does the RVIA allow the use of no hub clamps on plumbing drains?
minilite2506 is offline   Reply With Quote
Old 09-02-2016, 08:30 PM   #2
Head Rambler
If the plumbing is cemented into the hub, clamps aren't required.
Do you have some non-glued plumbing that's not clamped?
Why do you ask if RVIA allows it?
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
Old 09-02-2016, 08:59 PM   #3
No Hub clamps
I have to make a repair under a sink going into the grey water tank. And have limited space. Just thought a no hub would be easier than cutting out a lot of piping.
Old 09-02-2016, 09:12 PM   #4
Head Rambler
We call those Fernco couplings. They're fine to use on drain and vent lines.
Gotta go campin!
Old 09-02-2016, 09:15 PM   #5
Keep in mind the drain lines are sometimes a different spec than home drains. I recently had to cut mine to replace a air inducer valve on drain. I could not find a new female adapter to fit at home centers/rv parts stores. I ended up using a fernco coupling. The mfg did not allow enough space to unscrew the vent so it was either cutting the pipe or tearing the entire counter top off to service this part..... The rubber coupling willbe an added benefit due to all the vibrations bouncing down the road!
mfMcFroggierPod is offline   Reply With Quote
Old 09-03-2016, 08:07 AM   #6
I don't see why a no hub would be an issue particularly in a vent line. No hubs are used all over the place in home repairs including underground. Now, I guess one would consider vibration in an RV, and I guess over time that could be an issue. Otherwise, you will need to find you an ABS slip coupling to do what you are needing to do. I would assume you are dealing with 1 1/2 inch line. You would need to go to a plumbing supply to locate an ABS coupling.
AS Rabbit
2016 Wildwood 195BH
2009 Silverado 1500
Asrabbit is offline   Reply With Quote
