Old 08-21-2016, 11:18 AM   #1
2016 Rockwood 8325SS
NO POWER!!! Shurflo 4008 Revolution
Just got finishing checking out our new unit for our up coming trip where the water pump will be needed. The 3 earlier trips were with full hookup, water pump did not play a part. The water pump did work last time it was checked, several months ago. I want to mention that this is pretty much a new unit. I have checked with the manual and it pretty much mentions every thing with power going to the pump and how it could act under different situations. All fuses have been checked all ok. I am trying to save a trip back to the dealer, an hour away, to have it fixed under warranty. When the pump switch is turned on at the panel, no noise from the pump. Any suggestions would help, otherwise I guess I will be calling tomorrow to make an appointment.
Barstorm is offline   Reply With Quote
Old 08-21-2016, 11:21 AM   #2
fonzie's Avatar
Find your pump and check the fuse if burnt (usually fuse a pump)
Fonzie
Nights Camped:2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42)
Old 08-21-2016, 11:24 AM   #3
Already did check before posting. Thanks
Old 08-21-2016, 03:03 PM   #4
FYI....Pump getting 12V power, pump not working, must be a new lemon made on a Friday afternoon. Appointment made to have pump replaced by warranty.
Old 08-21-2016, 03:34 PM   #5
fonzie's Avatar
Pump will not come on if trailer hook up to city water. If 12 volt at pump, then I would tap the end of water pump where pressure switch is, might be stuck.
Fonzie
Old 08-21-2016, 03:54 PM   #6
Flybob's Avatar
If system shut down after being connected to city water ( leaving the system pressurized) the pump may not run. Open a faucet and try again.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 08-21-2016, 04:45 PM   #7
Talk about weird...took the suggestion about tapping end. Pump working when kitchen sink water on, also shower. The bathroom sink and toilet not working.
Nothing to the eye to suggest something is blocking the water flow. Still looking to make appointment tomorrow unless I can fix what's wrong.
Old 08-21-2016, 04:49 PM   #8
fonzie's Avatar
Probably debris inside water line. Take aerator out at sink faucet and clean it. For toilet would need to take line behind it and flush it. Also toilet valve is probably plugged.
Fonzie
Old 08-21-2016, 06:50 PM   #9
This post is for Fonzie, thank you. It was exactly what you said. the sink screen was clogged as well as the toilet line screen. Everything is fine, no appointment needed tomorrow. Once again the forum comes through with advise.
Old 08-21-2016, 07:01 PM   #10
fonzie's Avatar
Fonzie
power
