Old 05-29-2014, 09:50 AM   #1
Mountain Goddess
No pressure to outside shower on TRB12
Hello, have a brand new TRB12 A Frame and took it camping with a full tank of flushed and de-winterized water tank. Got fine pressure inside at the sink, but zero pressure (only a trickle) from the outside shower. I forgot to install the filter so that's not an issue. The pump works fine. Any thoughts? Thanks in advance!
Annabanana is offline   Reply With Quote
Old 05-29-2014, 09:53 AM   #2
Debris in the faucet or hose. Remove the restrictor also.
Old 05-30-2014, 03:51 PM   #3
Mountain Goddess
Thanks, Old Coot, there is no restrictor. I will try to see if there is debris in the hose, but it's a brand new camper so wouldn't have thought that was possible. Will check it out when I get home. Thanks again!
Old 05-30-2014, 03:53 PM   #4
New campers are notorious for debris in the plumbing. I have had to clean the faucets on every faucet on every new camper we've had since 1976.
pressure, show, shower
