Old 03-27-2018, 12:20 AM   #1
No water after filter was installed
Just installed the first water filter in our 2017 Sunseeker Motorhome. Don't know what the problem is, once the filter was installed, turned on the pump and opened the faucets and there is no water coming through the lines.
Any suggestions?
jopedersen is offline   Reply With Quote
Old 03-27-2018, 05:45 AM   #2
Any suggestions?
Were you using the System "Without a Element Installed" and now you have installed it and No Flow? Do you have Flow using "City Water"? Youroo!!
Old 03-27-2018, 06:30 AM   #3
jeff64's Avatar
Any suggestions?
Since this is your first time, is the winterization valve (the valve positioned before the pump) still turned to draw from the antifreeze port? Try rotating the selector lever to be in-line with the hose coming from the freshwater tank
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
Old 03-27-2018, 09:27 AM   #4
No water after water filter change
Hi
New motorhome, came with the filter system but the dealership did not install the water filter. During the walk through the turned on the kitchen tap and there was water flowing. Not sure now if they were hooked up to the city water or not. We have not used the water and installed the filter, opened up all the taps, waited a bit and then turned on the pump, water started to come through and then slowed to nothing.
No problem with the water flowing when hooked up to city water. All taps inside and the outdoor shower works on city water. I can see the water flowing through the filter.
Thks
Old 03-27-2018, 09:33 AM   #5
Kaadk's Avatar
If it works on city water, it's probably not an issue with the filter.
Just to check, are you sure there's water in the FW tank for the pump to use?
Old 03-27-2018, 09:37 AM   #6
Can't remember the brand of system I had when it happened but I put the filter in upside down (didn't know there was a right side up) and the flow stopped.
Go UK is offline   Reply With Quote
Old 03-27-2018, 09:43 AM   #7
Yes, it is in line.
Old 03-27-2018, 09:44 AM   #8
Yes, there is water. The dealership filled the water and we can see the level is full on the control panel
Old 03-27-2018, 09:46 AM   #9
Filter can go in either way, exactly the same top and bottom
Old 03-27-2018, 10:16 AM   #10
bubbles's Avatar
have you checked post #3 off your list? There also is an inline strainer between the holding tank and the pump. Verify it is not clogged.
Old 03-27-2018, 10:26 AM   #11
AquaMan's Avatar
When you turn the pump on, does it build pressure and turn off?
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
AquaMan is online now   Reply With Quote
Old 03-27-2018, 10:27 AM   #12
Out of Order
Had the same thing happen at a site in NorCal. Turns out the water supply at the campground had silt buildup and instantly clogged the filter, choking off the water supply. Took the filter off and all was well. Have you tried running water w/o the filter attached?
Todt and Connie and Hank the Doodle
2016 Wildcat Maxx 24RG
2016 Ford F250 6.7L Diesel
todtc318 is offline   Reply With Quote
Old 03-27-2018, 03:46 PM   #13
In order for the pump to pull water out of your tank make sure the filter bottle is full of water when you put it back on or the pump will not work. Ask me how I know.
No more shoveling is offline   Reply With Quote
Old 03-27-2018, 04:09 PM   #14
Check the actual filter both ends should be open, Aprox 1 inch opening on each end. I had purchased a filter that had 2 very small holes 3/16 in the center of the filter and had no water flow from it. Got the correct filter and that corrected the problem.
2014 SUNSEEKER 3010DS
TOADS, 2012 FOCUS OR 1998 JEEP WRANGLER,
Kevin & Judy is offline   Reply With Quote
Old 03-27-2018, 04:38 PM   #15
No water after water filter installed
Yes, the filter was full of water. How do you know.
Thks
Old 03-27-2018, 04:38 PM   #16
Brand new filter, first one to be installed
Old 03-27-2018, 04:39 PM   #17
Pump turns on but no pressure to move the water
Old 03-27-2018, 09:26 PM   #18
No water after new filter
If you disconnect fw line and hook up winterizing tube in water do you get water were through pump? It only takes a small drop of ice to make pump fail at the . Try unhooking discharge side of pump and see what happene.
overeasy is offline   Reply With Quote
Old 03-27-2018, 09:28 PM   #19
Pump doesn't build pressure so it doesn't shut off
Old 03-27-2018, 09:30 PM   #20
The filter is the same on both ends with one inch opening. The dealer supplied the filter just didn't install it.
led, water
