No water flowing from the washbasin taps ??
Hi all,
Yesterday, I installed a washing machine in the RV tunnel. To do that, I had to T into cold water line and released all the water pressure from the plumbing. Once done, I restored the water.
Now, the hand basin taps will not pass water, either hot or cold. All other outlets are fine - sink, shower, toilet all fine. It seems that the loss of pressure has caused some valve/blockage to occur in the tap set (2013 Rockwood, the tap has two levers, hot and cold, that rotate inwards towards each other).
Any tricks with these tap sets ?
