Old 05-13-2018, 07:57 AM   #11
Thanks for all the replies. The model number on the WH is 2GWHAM. Also, I wanted to clarify that we have no water at the hot faucets. Cavey, you are correct. The only way to get any water to the hot water faucets is to turn the HWH bypass valve.
I beleive the HWH is LP only except the 12v switch wire to ignite the pilot when needed.
I guess I will pull the HWH out this morning and see if I can locate the anti syphon valve that RCLOGG spoke of.
Waynebruner is offline   Reply With Quote
Old 05-13-2018, 08:05 AM   #12
rclogg's Avatar
just found this on Utube
'14 Cummins Dually Aisin 4.10
'07 FR Cardinal LE 30RK
'03 Cummins Dually 45RF
'01 Exiss 300MT Weekender
A wife and two dogs, isn't that enough?
rclogg is offline   Reply With Quote
Old 05-13-2018, 08:19 AM   #13
cavie's Avatar
Thank you. I'm glad that in my senior years I can still understand the English language as it is written. Now, if we could only get people to call a pig a pig. I personally have never owned a hot water heater. I've never seen the need to heat hot water. Plan old water heater works for me.
2002 27rk Wildcat 5er.
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
cavie is online now   Reply With Quote
Old 05-13-2018, 09:38 AM   #14
woodyrock1's Avatar
Oink oink
05 Ram 3500 Cummins Dually
14 8280WS Rockwood Sig. Ultra Lite
Prodigy 3 brake Controller
TST 507 TPMS
2017 = 30 nights /
2018 = 7 nights
woodyrock1 is offline   Reply With Quote
Old 05-14-2018, 10:12 AM   #15
Got it Fixed
Just wanted to thank everyone for their help. I pulled the water heater out last night and the is no check valve but I did find a small strainer in the inlet (cold water) side. After pulling it out I noticed that there was a lot of build up. I checked the main water filter and found that the factory didn't install the filter in the filter canister. The 'extra' that I found in the kitchen, apparently wasn't an extra.
The second bathroom still has very low flow. When I get home this afternoon I plan to pull out their shower faucet and see if there might be a small strainer at the inlet to the faucet as well.
Old 05-14-2018, 10:34 AM   #16
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
I'm glad you found the cause of the problem, living without hot water is no laughing matter.
To the factory's defense, they don't install the filter element because, at least in this part of the world, all units are being shipped winterized and the plumbing antifreeze would mess up the filter.
Since the strainer on the Girard was filled with crud, I suggest you inspect all taps, clean the aerators and flush the whole system, don't forget the strainer on the water pump inlet. However, the dealer should have installed the filter as part of the PDI.
2018 RAM 5500 Laramie CC
Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Cypressloser is offline   Reply With Quote
Old 05-16-2018, 03:54 AM   #17
woodyrock1's Avatar
Glad you found the cause to your problem. Happy camping and safe travels.
TST 507 TPMS
2017 = 30 nights /
2018 = 7 nights
faucet, hot water, water
