Old 06-02-2017, 03:35 AM   #1
No water from city water source
Hello all!
We just bought a 2017 Wildwood 31KQBTS. Had it out once and had a lot of problems getting water from the city hookup, but it was still cold (snow still on the ground cold) and the campground had just turned back on their water for the season so we chalked it up to that and used the fresh tank.
Now we're on out second trip and are having the same issues, so obviously it's something else.
Great water pressure with the tank and water pump. Nothing from the city hookup. Is there a switch/value somewhere we've missed on this model? Water flows great through the pressure gauge and water filter, so we know there are no clogs, etc there. Water to all faucets with the fresh tank and pulp, no issues there. It's literally as soon as we screw the hose into the city water connection.
Any suggestions/advise greatly appreciated! Thanks all!
medicKH is offline   Reply With Quote
Old 06-02-2017, 04:30 AM   #2
kdp1897's Avatar
Sounds like a valve is closed somewhere. My old rig was a Wildwood X-Lite but it didn't have one. But that's not to say the newer ones don't. I would start looking where the city water supply comes in. Good luck.
2017 Rockwood Ultra V 2618VS
2017 GMC Sierra 1500 SLT Crew Cab Z71, 5.3 EcoTec V8
Nights Camped: 10 (so far) in 2024; 28 in 2023
kdp1897 is offline   Reply With Quote
Old 06-02-2017, 06:39 AM   #3
gkochel's Avatar
I would experiment with your winterization bypass/shut off valves. Something may have been plumed wrong and with trying different open shut etc you may discover the problem.
2015 Cedar Creek 34RLSA Touring
2004 Silverado Duramax Crew Cab Dually
gkochel is offline   Reply With Quote
Old 06-02-2017, 06:45 AM   #4
crunchman12001's Avatar
Look inside, behind the city water connection. I would trace the line to find the kink.
You can also remove the sediment screen on the city water connection and depress the check valve. (with the system depressurized.)
2015 F-250 FX4
Old 06-02-2017, 09:17 AM   #5
Kenny kustom's Avatar
Andersen valve turned the wrong way ?
2017 Dynamax Isata 4
Old 06-02-2017, 11:50 AM   #6
I have the same camper, but a 2016
pull out your rear right side drawers to see the water lines. Check for kinks like others said.
While you are there - make sure all the connections are tight. Mine leaked last year at this area.
if the kink isn't here, then it must be somewhere else in the water line where you can't see it. You could try crawling under the camper to look?
if nothing else, take it in for service... you are still under warranty.
mkosu04 is offline   Reply With Quote
Old 06-02-2017, 12:02 PM   #7
Can you post a photo of your connection? It might help with answers.
Some units have a water bay with various valves you turn to select city water/fill fresh tank/etc.
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=90
Old 06-02-2017, 12:07 PM   #8
Herk7769's Avatar
There is a one way check valve and filter screen as part of the inlet connection. That valve can stick closed and the screen can rust shut.
Might be time to replace the unit and is well within the average DIY'ers skill set.
https://accessories.lazydays.com/jr-...2x0aAhk58P8HAQ
I would try replacing the screen washer first and while it is out, jiggle the little plastic nub on the check valve with water pressure from the water pump. If it won't shut off again, you will need to replace it so have one on hand (or a spare hose thread backflow valve or plug) to screw in.
https://www.dripdepot.com/item/hose-...Qy4aAjQe8P8HAQ
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 06-02-2017, 12:07 PM   #9
Wildwood City Water
Mine is a 2014 model, but there are no valves between the water intake point and the faucet valves. You have to have an obstruction somewhere in the system. You should be able to simply hook up to city water and use it.
JimMorrell is offline   Reply With Quote
Old 06-02-2017, 12:07 PM   #10
should just be a connection on the back like this, unless they changed since the 2016 model year.
(the water filter/regulator is my custom design)
Old 06-02-2017, 12:20 PM   #11
Herk7769's Avatar
The water intake point has an internal check valve as part of the valve.
This is required to keep the water from shooting out when you use the water pump and fresh water tank.
The attached repair article is from JohnB of Radnor Ohio; Thanks John.
ID:	139876   Click image for larger version
File Type: pdf How to Repair a City Water Inlet valve.pdf (841.0 KB, 164 views)
Old 06-02-2017, 07:31 PM   #12
Hmmmm---I don't know what an Anderson value is, or how to tell if it's turned the wrong way--can you give me some details?
Old 06-02-2017, 09:02 PM   #13
This was the problem! Thank you so much for the advice---straightened out the hose and it's running like a champ!
Old 06-02-2017, 09:03 PM   #14
Thank you all for the words of wisdom! It was a linked line under the drawers in the back. Thanks to all the advice---we've got lots of water now!
Old 06-02-2017, 09:07 PM   #15
Thanks for the reply and letting everyone know what you found and how you corrected the problem. Others will probably benefit as well.
extxn is offline   Reply With Quote
Old 06-05-2017, 11:42 AM   #16
glad it worked.
Hopefully you saw my note about tightening your fittings too!
It will save you a mess to clean up like I had...
city water, water
