Old 07-15-2016, 12:36 PM   #1
No water. Help!
2017 microlite. 2/3 full freshwater tank. Turned on pump (connected to 30 amp), opened faucets. Nothing. Is there a valve to open? No clue given in owners manual.
hoosierhappywanderer is offline   Reply With Quote
Old 07-15-2016, 12:41 PM   #2
Flybob's Avatar
Make sure the winterizing valve ( antifreeze suction line) just before the pump is set to the summer position. Should be parallel to line from tank. If in doubt try in both positions. See photo
Name:	antifreeze adapter.png
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 65W solar panels
Old 07-15-2016, 12:41 PM   #3
Either the W/H is filling or your A/F valve is still on! Youroo!!
Old 07-15-2016, 12:46 PM   #4
jeff
jeff64's Avatar
X2 valve at pump inlet either pulls water from the tank or from the antifreeze(winterizing )port . Can't believe on a new TT that should have had a PDI that the dealer would have left it in winterizing position.
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
Old 07-15-2016, 11:34 PM   #5
Thanks, everyone! Special this to Fred Yoder who stayed on speakerphone to help locate the disconnected wire on the water pump. Not sure how it happened, but suspicious of repair for a leak done last April by our dealership. At least we know the pump is under the dinette bench now!
Old 07-16-2016, 05:22 AM   #6
I bet the Next time your Post will say " Turned on the water pump and NO Pump SOUND,they do have a Distinct/Annoying Sound,especially in a Microlight under the Dinette Seat"! Youroo!!
water
