Old 08-15-2010, 07:40 AM   #1
No Water Pressure
Water system won't pressure up. I can turn the pump on and it runs but wont pressure up the system. When I turn it off I can hear water back flowing into the holding tank. Can hook to shore water and everything is fine. I believe it's the check valve.......question is....where is it and where can I get one ?? Thanks !!!
Clyde2FJ40 is offline   Reply With Quote
Old 08-15-2010, 08:23 AM   #2
I first have to ask the obvious, do you have enough water in the tank? A check valve normally is only necessary to maintain a pressurized system when the water pump is turned off. And it is typically built into the pump.
First things first, add water to the tank, then disconnect the outlet of the pump and see if you get water when the pump is turned on. Yes/no? Yes, connect back to the system and go turn the pump on again and bleed the system. NO, clean the filter screen and or replace the pump.
Old 08-15-2010, 10:22 AM   #3
Donn....yes, the tank is full. Will try your other suggestions and see what happens. Thanks.
Old 08-15-2010, 11:03 AM   #4
milzat's Avatar
Clyde,
The links below may help.
RV Water Pump
How To Diagnose Water Pump Problems Before Repairing Or Replacing RV Water Pumps
Water, Water, Everywhere!
milzat is offline   Reply With Quote
Old 08-16-2010, 09:22 PM   #5
The Old Man
Willis's Avatar
Do you have a bypass near your pump for winterizing? Perhaps the valve is open so it's just sucking air?
2010 Flagstaff 829RGSS
Still to go: AK, NL, NT, NU, YT
Willis is offline   Reply With Quote
Old 08-16-2010, 09:28 PM   #6
I did that once and had the same problem you are having. Check to see if you have a valve near the water pump that needs to be opened to allow water from the tank into the lines.
Hokiehall is offline   Reply With Quote
Old 08-16-2010, 11:01 PM   #7
Let's see what we have here. City water connection works. We can assume plumbing is in pretty good shape. Have no idea of the year/model of the camper since it is not in the signature. Don't know if you bought it new or used.
Does this trailer have a water pump winterizing kit on it? This would be a valve on the suction side of the pump to draw antifreeze in to the pump instead of water from the supply tank? Sounds to me like a supply problem for the pump. The check valve in question here, won't keep you from pumping water normally, it is there just to maintain pressure when there isn't any water flowing. The pump should pump water without a check valve, and I think most are inside the pump. Find the pump, and look at both the inlet and outlet side side hoses. Maybe there is a valve there.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
