Old 07-22-2015, 03:56 PM   #11
we had a similar problem with our 2 week old travel trailer. Pump running but only water we got was in spurts, no solid streams. This was the same in all faucets. We got out the pump manual and found that we were to let it run with all faucets open until we got water. No luck just spurts after 20 mins. Finally we discovered a valve that had to be turned to allow water to reach the pump. That valve is located in the same compartments as the pump but is nearly out of site if you are looking in from the outside. It is visible from the inside so once turned and the handle pointing the right way, we got water to flow from the fresh water holding tank to the pump and through all the piping. We now be happy campers!
John Spear
RMCS (SW) USN Retired
2012 Ford F-150
Rockwood 2503s
debandi is offline   Reply With Quote
Old 07-28-2015, 05:17 PM   #12
Summer2Go
Summer2Go's Avatar
😜. and where would that be on a Roo? I can hear water running, but still getting air from faucet. I checked the hot water tank, and seem to be allowing air to escape when I check. If it's filling the six gallon in the water heater it's taking forever. I don't see a valve or switch by the pump......
Summer2Go is offline   Reply With Quote
Old 07-28-2015, 05:31 PM   #13
Summer2Go
Summer2Go's Avatar
Oh my gosh! What were they thinking...... Nothing in the manual, anywhere, about turning a switch to go from city water to fresh water tank! I found the switch up in the front corner of the trailer above the water pump, BEHIND the pipe to the water pump, through the storage door you can barely fit through to see anything. Common sense told me you probably had to turn on something other than the water pump, but the manual says nothing about it.
Old 07-28-2015, 05:32 PM   #14
Summer2Go
Summer2Go's Avatar
Oh and thanks debandi!
Old 07-28-2015, 05:39 PM   #15
Georgia Frog Rally 2018
aceinspp's Avatar
Manuals are general and mostly useless. Later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
Old 07-28-2015, 11:38 PM   #16
bikendan's Avatar
Summer, this is correct.
You need to stop using the manual as gospel.
It's only good for general understanding of RV systems and has nothing to do with your particular model.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 07-29-2015, 09:19 AM   #17
We had called the dealer about the water problem and had to wait many minutes for a call back. Then the "TECH" said lets try a few things.
While waiting for the call back from the dealer we had discovered what needed to be done.
FYI the PDI did not cover this procedure.
John Spear
2012 Ford F-150
Rockwood 2503s
Old 07-29-2015, 09:27 AM   #18
Ford Idaho's Avatar
Almost is correct, I understand they do make rather good fire starters.
Old 07-29-2015, 12:46 PM   #19
Summer2Go
Summer2Go's Avatar
My PDI did not cover dimly, and I am new to having a trailer coming from a bathroom less pop-up. My daughter who came with me, confirms that I heard him say I had an 80gal. fresh water tank. It's a small Roo, and well documented to have a 30 gal. one.
Old 07-29-2015, 12:47 PM   #20
Summer2Go
Summer2Go's Avatar
Sorry, type-0......"didly".
pressure, water, water pump
