Old 07-20-2015, 10:09 PM   #1
Mark
No water pressure
Water pump power light on, full tank, no water flow. RV is 6 weeks old. Before I call FR, any thoughts? I'm very new to this 😳
marky411 is offline   Reply With Quote
Old 07-20-2015, 10:24 PM   #2
Blackhat6mike's Avatar
Does the pump run? Many different things that could cause your problem ie crimped water line, trash stuck in the pump, check valve stuck, etc. Need more info.
First, can you hear the pump come on when you open a faucet?
Aviator Wright Flyer #1919
Army Pathfinder Vietnam, 3 tours
DAV, MOPH, VFW, NRA, 1stCav. ABN
Blackhat6mike is offline   Reply With Quote
Old 07-21-2015, 08:25 AM   #3
Mark
When I open one of the faucets in the kitchen or the head, I don't hear the pump running. However the pump runs and flushes the toilet fine.
Old 07-21-2015, 08:29 AM   #4
RETIRED
n-e-d's Avatar
Could be debris clogging your sink aerators. Unscrew and try running water again. How about outside shower? Does that run.
Mary and Me
2015 2650s "Finally"
2015 Jeep Cherokee
2016 Ford Race Car Red 350HD Cargo Van HR DRW EXT DIY Daytripper "Red Roamer"
n-e-d is offline   Reply With Quote
Old 07-21-2015, 08:32 AM   #5
Its Not your Pump! Check your outlet ends for (Building Debris)! Youroo!!
Old 07-21-2015, 08:37 AM   #6
TURBS's Avatar
X2
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "15 nights"
Old 07-21-2015, 09:55 AM   #7
Mark
Thanks for y'all's help! Once I realized what you meant by outlet ends and building debris lol I checked the faucet aerators and lo and behold they were filled with white crystals. Never would've guessed that since the RV is so new and I haven't even run 10 gallons of water through the faucets. again thank you very much for the help!
Mark
Old 07-21-2015, 09:56 AM   #8
TURBS's Avatar
Happy camping!
TURBS
2011 32bhok Sabre
Old 07-21-2015, 10:07 AM   #9
Mark you can even click the (Thanks Box) and give Turbs a (Thank You!) Camp On! Youroo!!
Old 07-21-2015, 10:30 AM   #10
accumack's Avatar
I don't know if you have water shut off valves. If you do check them to make sure they are open.
accumack is offline   Reply With Quote
pressure, water, water pump
