Old 10-11-2013, 10:09 AM   #1
No water pressure from city connection, but fine from the tank
I have a 2012 Wildwood 29BHBS. When hose is connected to city water, i get a burst of pressure then a little dribble. When I fill my tank, i can run off of it fine. Any and all sugestions will be very helpful.
atkinssd is offline   Reply With Quote
Old 10-11-2013, 10:12 AM   #2
dcheatwood's Avatar
Does water flow through hose from cg faucet OK when disconnected from RV?
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
Old 10-11-2013, 10:20 AM   #3
bubbles's Avatar
Is your water pressure regulator stainless? They will shut down after a few times using. Don't know why. Take regulator out of loop to check.
Old 10-11-2013, 10:23 AM   #4
Yes Water flows fine from the source. I have taken the regulator out of the loop as well.
Old 10-11-2013, 10:36 AM   #5
kc8lvy's Avatar
Check your screen where your hose hooks to your camper a friends camper was plugged with rust there.
2004 Dodge Ram 2500HD Cummins
2017 Keystone Montana 3820 FK
2009 Harley Davidson Ultra Glide
kc8lvy is offline   Reply With Quote
Old 10-11-2013, 10:45 AM   #6
w4drr's Avatar
Sounds like the check valve on your city inlet may be toast.
Bob
Bob & Doris
Roanoke, VA
2009 Toyota Tundra CrewMax 4x4 - 5.7L - 6 Speed Auto - 4.30:1
2013 Rockwood HW296
w4drr is offline   Reply With Quote
Old 10-11-2013, 10:46 AM   #7
bubbles's Avatar
Seems the only other reason would be as previously stated or perhaps a check valve at the trailer input. Go figure.
Old 10-11-2013, 10:56 AM   #8
Luvnlife's Avatar
I had the same problem on my rig. After checking all of the above, when I pulled out the city fill fixture I noticed the hose had a kink in it. The hose was looped so I would get some water initially, then as pressure built up it would close off at the kink. Straighten out the hose. Now everything works fine.
Luvnlife
Larry and Mary
Solera R 2013
Luvnlife is offline   Reply With Quote
pressure, tank, water
