Old 08-02-2010, 11:13 PM   #1
Burr Rabbit's Avatar
No Water running to faucets or toilet with city hookup or water tank.
Just left a campground last week and all was fine. Preparing to go again this week and noticed no water flow to faucets or toilet, but the in door and out door showers work fine. Water tank is 2/3 full and pump comes on when shower turns on but will not come on when toliet, kitchen or bathroom sink is turned on. Hooked up to city water thinking the pressure would help, but to no avail, same problem. It is a 2010 Georgetown 379. I did use the black tank flush valve when leaving the campground, does anyone think that had anything to do with it. Any help is very much appreciated. Thanks.
Burr Rabbit is offline   Reply With Quote
Old 08-02-2010, 11:31 PM   #2
You may have same debris in your faucet screen and maybe in water inlet to toilet just unscrew the tip of your faucet and clean it out.The toilet maybe a little harder but cant tell you for sure how to from the top of my head sorry
2008 8296SS Rockwood Signature Ultralite
2002 Silverado 2500HD extended cab
chevy02 is offline   Reply With Quote
Old 08-02-2010, 11:36 PM   #3
NWJeeper's Avatar
The black water flush is totally separate from the plumbing system in the rig so it would not be the cause of the problem. I would suspect debris in the line somewhere. Are all the effected items in the same general area?
Ed & Wendy
www.nwjeepn.com
Old 08-02-2010, 11:52 PM   #4
Not sure if they are all on the same line, but makes sense. I will add that the water filter was full of debris and in need of a change. I have removed it but still no change. Water pressure in the showers is great, but little to nothing anywhere else. Will check for debris. Thanks.
Old 08-03-2010, 12:28 AM   #5
NWJeeper's Avatar
Hmm, maybe a tedious job but I would be inclined to disconnect the line coming out of the pump to the system then figure out a way to apply compressed air to each faucet to back flush the system. No more than about 50lbs pressure. It would require making some fittings to attach to the faucets or directly to the lines to the faucets by unscrewing them under each sink. Place a container on the end of the line to see what comes out with the water that is in the line. If there is a lot of debris in the filter it stands to reason there may be more that is clogging your lines somewhere else.
Ed & Wendy
www.nwjeepn.com
Old 08-03-2010, 01:43 AM   #6
Well that was it. Debris in the lines. I just emptied the fresh water tank, changed the water filter. disconnected the faucet screens and let good clean water run through the system. The toilet was a little more difficult, had to pull it, disconnect the valve off the back and clean it multiple times with water and compressed air. The debris appeared to be tiny rocks and sawdust, sand and even some plastic shavings. Makes me think it could be from construction at FR given it is a 2010 model and it finally collected enough to shut things down. Or, just got back from the Outer Banks of NC and campground may have some sand in their water connections. Probably a combination of both. Anyway, thanks so much for the great advice from you guys, this forum never lets me down. Safe travels my friends.
Burr Rabbit
Old 08-03-2010, 05:56 AM   #7
Iggy's Avatar
Burr Rabbit GREAT JOB!
The bottom line is that you found the problem and make the appropriate repairs. Everyone here learned from your experience.
Thanks.
Old 08-03-2010, 10:05 AM   #8
Villa Estate 392FLFB
The_Stuff's Avatar
glad it worked out for you. Im still amazed at the amount of debris from construction is these trailers after being made...
The_Stuff is offline   Reply With Quote
Old 08-03-2010, 10:25 AM   #9
MtnGuy's Avatar
Y'all people keep some late hours !!
It shows the 1st post @ 12:13a, and the problem fixed @ 2:43a. I can understand NWJeeper responding from the west coast, but most others are on the East Coast.
More power to y'all.
Old 08-03-2010, 10:48 AM   #10
powerboatr's Avatar
Burr Rabbit
its not just FR
our damon was full of odds and ends in the lines and holding tanks
not to mention the loose fasteners we found hiding out everywhere
mof last time out a huge piece of plastic blocked up the gray drain
glad you found your culprits
Name:	Extra Screws1.jpg
Living in the Piney Woods of Texas.
powerboatr is offline   Reply With Quote
faucet
