Old 10-14-2010, 08:05 PM   #1
No water to kitchen sink
So I'm hooked up to city water and get water at all the bathroom areas (sink, shower, toilet) but I don't get water to the kitchen sink. What's going on? Could the line have some sort of vapor lock?
jimreflex is offline   Reply With Quote
Old 10-14-2010, 08:18 PM   #2
You probably have debris in the end of your faucet unscrew the end and clean it out
2008 8296SS Rockwood Signature Ultralite
2002 Silverado 2500HD extended cab
chevy02 is offline   Reply With Quote
Old 10-14-2010, 08:27 PM   #3
nope no debris at faucet....
Old 10-14-2010, 08:29 PM   #4
Can you hear your pump come on when you turn the faucet on?
Old 10-14-2010, 08:46 PM   #5
chevy02, he said he was hooked up to city water- no pump is needed. There is a filter usually under the kitchen sink area that is a cartridge style that may be stopped up, if there's nothing in the faucet aerator on the end. I'd start there. Randy
Old 10-15-2010, 11:53 AM   #6
Thanks Randy. Tried the filter with no luck. Any other thoughts?
Old 10-15-2010, 11:59 AM   #7
Wanna Be Camper
SaskCampers's Avatar
Is it hot and cold that do not work or just one of them? One other thing, have you tried going back to your onboard supply and running the pump to see if it still works that way?
John & Deb
2011 Flagstaff V-Lite 30WRLS
Days Camped 2016: 3 2017: 0
Old 10-15-2010, 12:00 PM   #8
Mr. Black's Avatar
You would have hot and cold at the kitchen sink.
Is this a single handle faucet? or a hot/cold knob faucet?
You get zero water? hot or cold? If it is a single handle then I would guess there to be a problem in the handle.
Otherwise if it were me, I would just start pulling lines apart until you find water flow and go from there.
Is your plumbing crimped connections or compression fittings? If it is crimped it is gonna be harder to troubleshoot if it is a problem away from the sink.
So yeah, climb under the sink and loosen the fittings at the sink and see if you get water. Be carefull and have pans and towels ready to catch water.
Steve
1999 Ford Superduty F250 PSD CC SB 6spd 4x4.
B&W goosneck/companion hitch, Airlift 5000 airbags.
2006 Sierra F28 Rear Kitchen 5th Wheel, 31' = 10k pounds.
Nights camped in 09-14, 2010-23
Mr. Black is offline   Reply With Quote
Old 10-15-2010, 07:38 PM   #9
try to disconect the supply pipe under you kitchen sink and run a test. If you have water and you should have water at the pipe please look at your faucet. You may have a cartridge problem?.
capucine is offline   Reply With Quote
Old 10-16-2010, 09:50 AM   #10
jimh's Avatar
Do u have both hot and cold in the shower? Seems like I read abt a similar prob and the water was shut off at the he heater.
jimh is offline   Reply With Quote
