Old 04-27-2013, 06:36 PM   #21
Steve & Phyllis
SteveBingham52's Avatar
Well what a surprise. It runs when plugged into power pole. My battery is good and will run lights and slides so I don't think that is it. I had a surge suppressor installed by dealer over winter and can't think of any other changes. Any ideas?
SteveBingham52 is offline   Reply With Quote
Old 04-27-2013, 06:39 PM   #22
TURBS's Avatar
Did the lights and slide work before u plugged in?
Old 04-27-2013, 06:43 PM   #23
Steve & Phyllis
Yes they worked great. I used them to open it to load it.
Bad storms tonight. Will unplug tomorrow and see what happens. If it had a blown fuse I don't think 110v would make any diff??? Would it
Old 04-27-2013, 07:07 PM   #24
TURBS's Avatar
No 110 should have made no difference other than to charge the battery via the converter.
Old 04-28-2013, 06:18 PM   #25
Steve & Phyllis
Decided not to turn off the power to see if water pump ran. I am at the beach for a couple weeks and just don't want to take a chance on something going wrong. Will let you know next week if I have any more info as I will check it when I am leaving. I know I know, what could go wrong. Tim the tool man Taylor should of been named Steve because things I touch have a way of breaking. And thank you for all the input.
Old 05-03-2013, 08:57 PM   #26
Steve & Phyllis
Got my water working! There is a small handle in the connection area that is not labeled. At some point for some reason I must have turned it. The water pump either can't get water from the tank or it can't pump it so the pressure was satisfied and it had no reason to run. During the five hour drive something happened to let the pressure off so then it would run but never stopped so I guess it couldn't build pressure. When cleaning out to leave I turned the little handle for no particular reason and the pump ran about 30 seconds and stopped and now the water runs just fine with the on board supply.
MORAL OF THE STORY: Don't turn little white handles that are not labeled (shame on you Forest River) when you don't really know what they do.
