Old 04-24-2013, 08:04 PM   #1
Steve & Phyllis
SteveBingham52's Avatar
No water! Whatbad timing.
We leave in about 36 hours on a long trip and now the water pump is not working. Worked just fine Sunday and no response on Monday. Only use it while traveling to potty but timing is a bummer. Books that came with it don't mention where it is located and I can't find it. Could someone tell me where it is on a 2012 Sandpiper 312re?
SteveBingham52 is offline   Reply With Quote
Old 04-24-2013, 08:07 PM   #2
TURBS's Avatar
Theres an inline fuse right next to the pump when and if you find !
It's normally real close to where the fresh water/ city water fill is .
turbs
Old 04-24-2013, 08:09 PM   #3
jtstromsburg's Avatar
I don't know where it would be located in your camper, but a couple ???'s does it make any noise at all or nothing? Are you sure the fuse is good?
Its probably near The bath, and close to the water hookups outside
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is online now   Reply With Quote
Old 04-24-2013, 08:46 PM   #4
If all else fails, put 2-3 gallon jugs of water in the shower to use for flushing while on the road between campgrounds and not fret too much over the pump until you have time.
Sirsea is offline   Reply With Quote
Old 04-24-2013, 08:48 PM   #5
TURBS's Avatar
Fuse should be next to the pump jt.
Old 04-24-2013, 08:51 PM   #6
cmptrkd's Avatar
I believe your fuse is behind the "docking station" as they call it, the panel where all the water connections are. I think there should be a removable panel either behind the docking station, or to the left side.
cmptrkd is offline   Reply With Quote
Old 04-24-2013, 08:55 PM   #7
cmptrkd's Avatar
Guess I said fuse because that's what everyone else is talking about, but I meant the pump. The pump is behind the docking station. Easiest to get to from the other side, a couple screws and you'll have it removed.
Old 04-25-2013, 06:22 AM   #8
Steve & Phyllis
No noise at all. Heading over to storage place to bring it home to load up in a couple hours. Will look around some more for it now that I know I am not looking for something great big. I admit I had no idea it didn't look like one around the house.
Old 04-25-2013, 06:26 AM   #9
TURBS's Avatar
Should look similar to this.
Old 04-25-2013, 07:59 PM   #10
Steve & Phyllis
I guess I surrender
I have looked behind drawers, under sinks and behind panels under the sink and I can find a LOT of lines and the water heater but no pump. I am beginning to think it may be under the trailer and inside the cover over the bottom. There is like a black cover over the whole bottom of the camper underneath. I did find some things that I will try to find out what they are for though. Guess I will do without it till July and take it to the dealer. Or maybe over the next few weeks at Ocean Lakes CG I might run into someone who knows where it is or how to fix it. I don't guess any of you will ever be calling me for advice on how to fix something However if you do ever need a software engineer who specialized in math and movement I can for sure help you out. For free of course.
