Old 06-09-2017, 04:34 AM   #1
Notice-Danger!
The "Pocket Hose Brass Bullet W Jet Nozzle 25 FT" is just that, a" High Powered Bungee Cord Bullet"! If you plan to use it your in for a Surprise! It is ONLY 15' useable UNTIL it is PRESSURIZED! So if you think you can hook it to the Hydrant and then attach it to your RV 20-25 feet away,GOOD LUCK! It has a Bungee Cord Recoil if you Let Go,and it will cause "Damage/Harm/or Death" if it hits you or the RV! When in the "Unpressurized State" it has Super Bungee PULL POWER" to dislodge your City Water Connection off the RV! The ONLY way I see these can be used at their "Advertised Length" is Hook to Hydrant first,then with a ADDED shut off Valve attached to the other end of the Hose,turn on the water supply then turn OFF the output valve,NOW Wait until the HOSE Expands out to its Advertised Length then hook up to your RV and turn the added VALVE on! The Disconnect after use is not Quite so VIOLENT! BUT be aware when disconnecting also! For a Normal Garden Hose use at Home with a Spray Nozzel attached these hoses might be fine,but be aware if you plan to use for RV Supply! Youroo!!
Old 06-09-2017, 04:47 AM   #2
That is some strong water pressure you have. My hose fills up in a graceful manner 😁
Danx2 is offline   Reply With Quote
Old 06-09-2017, 05:17 AM   #3
"On the road again"
rjshiflet's Avatar
I'd never use one for drinking water - I don't believe they're approved for drinking water, but as Danx2 says above - mine works gracefully for use with my black tank flush. I suppose I've got a different brand (same type of hose though) because mine came with a cutoff on on the male end of the hose.
Robert & Estha Shiflet
Georgetown XL 378TS
Jeep Gladiator Willys Tow Vehicle
rjshiflet is offline   Reply With Quote
Old 06-09-2017, 07:55 AM   #4
Broken Toe
Cowracer's Avatar
I miss my old Toro Compact 50 flat hose. That thing was awesome. Took up less space than a mouse's ear, and you could pack it up in about a minute flat.
Only downside was you had to let out all 50 feet off the reel before you could use it, which kinda sucked when you only had to go 10 feet. But other than that, it was awesome
FROG Member MO-0008-571 Since 20124444444444My Project Blog: https://cowracer.blogspot.com/
"Camper" 2016
Rockwood Signature Ultralite 8329ss
"Casper" 2017 Ram 2500 Laramie Diesel
..ProPride 3P Hitch - "Yeah. It's worth it."
Cowracer is offline   Reply With Quote
Old 06-09-2017, 08:44 AM   #5
Phat Phrog Stunt Crew
elind's Avatar
I used one of these years ago when I had my pop up.
2014 Wildcat 327ck
elind is offline   Reply With Quote
Old 06-09-2017, 08:50 AM   #6
Who Dares, Wins
doc73's Avatar
Did you experience the "impact" of the bungee?
2015 Chevy HD D-Max
2022 Impression 315MB
doc73 is offline   Reply With Quote
Old 06-09-2017, 08:51 AM   #7
glsimms's Avatar
I used one of these. And you're right, you had to unroll all 50 feet to use it. But it was very compact and easy to store
Gerard
2017 Coachmen Apex 269RBKS with Summit Pkg.
2014 Ford Expedition with factory installed HD tow pkg.
Blue Ox SwayPro WDH
glsimms is offline   Reply With Quote
Old 06-09-2017, 08:53 AM   #8
MacGyver could use that hose to take out a whole group of terrorists.
2012 Windjammer 3001W
2016 Sunset Trail Super Lite 250RB-For Sale
2015.5 Chevrolet Silverado 2500HD LTZ crew cab Z71 4x4
KingFisher is offline   Reply With Quote
Old 06-09-2017, 08:58 AM   #9
Who Dares, Wins
doc73's Avatar
I had one of those hoses then after about a year I turned it on one day and I was watering the CG lawn with all the pin holes in it. I did just get one of those Zero G hoses and they seem to work well.
2015 Chevy HD D-Max
Old 06-09-2017, 08:59 AM   #10
Who Dares, Wins
doc73's Avatar
Ballpoint pen, Duck tape and a paperclip and he is golden...
2015 Chevy HD D-Max
